The Bluetooth driver breaks every time I restart my Dell (L502x).
I install the driver, add some audio bluetooth devices (with "listen to music" option) and works ok, but if I restart the pc, and link again my audio devices the volume mixer turns the volume up to 100% and the audio wich send to my device is very low.
I can only fix it if I uninstall the device (with all the intel software), and install it again (downloaded from dell.com or intel.com, last versions, I have the same problem).
The driver name is intel centrino wireless bluetooth 3.0 + high speed virtual adapter.
My OS is windows 7 ultimate 64bits, and the drivers are for 64bits os.
In linux Ubuntu I haven't got any problem (I have dual boot).
Has anybody got the same problem?
Note that this is an uncommon behavior of the Bluetooth device drivers. The latest drivers/software available is version 1.1.0.0 available here:
from your description, it may be related to some corruption occurring once the computer is turned off, you may check if you disconnect/"un-pair" the Bluetooth devices before you turn the computer off/standby, if you still see these corruptions, also you may check if there are any updated drivers for the paired audio device you add.
