I'm running the Samsung Ativ Series 9 Book Plus. Was installing the 7260 Wireless-N software update 17.0.1405.02. Since I did that, my Bluetooth is gone. Not visible in Device Manager, not able to connect anything, nothing... Anyone have an idea what would cause that?
Window 8.1? Could you install 1405 and cold boot (shutdown /p). After booting into the OS again, you should see Generic Adapter in Device Manager. Then try installing https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24191&lang=eng&ProdId=3827 Intel® Download Center (32 or 64)? Make sure you perform cold boot between uninstall and re-install steps.
Hey diceman,
did this work for you? Which form factor does your 7260 Card have? Mini-PCIe oder NGFF/M.2?
Cheers
Bjson
