I have a Lenovo U430 Touch laptop with an Intel 7260-N WiFi&BT combo running Win 8.1. I'm stuck with Bluetooth driver 17.0.1405.0464. I tried updating it to the last 2-3 versions, installation works just fine but driver version does not change even after reboot. I tried uninstalling the driver in Device Manager, repairing installation and removing the driver using Intel's driver menu, still stuck with this version. Any ideas on how to update this stubborn driver?
Hi waves,
I am sorry you are having this problem but let me help you.
I would like to know some more information about the issue you have so can you provide the following?
Kevin M
Thanks for the information. Can you please provide your dxdiag report and the MSINFO32? Please attach both documents.
Kevin M
I don't see a way to attach files to this post.
I shared the files with you Kevin.
Any news?
Hi Waves,
Thank you for the information.
I recommend you uninstalling again completely the driver you currently have (both Wireless and BT) and the install the Wireless driver first:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24170 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24170
After that, try installing the BT driver at this location:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24189 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24189
Try this again and let me know.
Kevin M
The links you sent are for Windows 7 drivers and I'm running Windows 8.1. Are you sure you want me to install Win 7 drivers on Win8.1?
I am sorry. Here you have the correct drivers:
Wireless:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24220 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24220
BT:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=23999 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=23999
Kevin M
