Wireless
8530 Discussions
Certificate request for Intel Wi-Fi 6E AX210
Ryan90
Our company is currently in the process of obtaining KC, UL, CE, and Japanese certifications for a robot we have developed.
We require certification documents for the Intel Wi-Fi 6E modules, AX210NGW and AX210D2W, which are integrated into the robot.
Could you kindly provide the necessary regulatory and certification documents for these modules?
The certificates we need are KC (South Korea), Europe/Radio Equipment Directive (RED), MIC (Japan), and FCC (USA).
Thank you for your assistance.
JedG_Intel
Hello Ryan90,
I understand that you're looking to obtain certain certification documents. I'll be checking this internally and I'll give you an update as soon as possible.
Jed G.
Ryan90
Hello Jed G.
Yes, I will wait for the reply regarding the certificate document. Thank you.
kevin310
Dear Ryan90
I'm currently communicating with INTEL and DEKRA regarding the same issue.
Have you obtained the CE and KC certification test reports?
If so, I'd like to ask if you could share them.
** Are you a Korean company? If you are, please contact us at <email removed for privacy>
Thank you.
JedG_Intel
Hi Ryan90,
I sent you an email with regards to your concern. Please check your inbox at your earliest convenience.
Jed G.
Ryan90
According to the document "ax210-regulatory-webflyer-ccg.pdf" provided by Intel, the AX210NGW and AX210D2W have received the following certifications. The document mentioned below is required.
[AX210NGW]
KC (South Korea) : R-C-INT-AX210NGW
MIC (Japan) : RF: 003-220254
FCC (USA) : FCC ID: PD9AX210NG
Europe/Radio Equipment Directive (RED) : Screenshot
[AX210D2W]
KC (South Korea) : R-C-INT-AX210D2W
MIC (Japan) : RF: 003-220255
FCC (USA) : FCC ID: PD9AX210D2
JedG_Intel
Hi Ryan90,
I already sent you an email with regards to this concern of yours. Please check your inbox as soon as you're free to do so.
Jed G.
Charlie7
Were you able you obtain/provide the RED radio Test reports? For the Intel AX210D2W/AX210NGW, referenced under certificate 841606 (reports TR11–TR16, 220222-02.TR05)? @JedG_Intel
If yes, I am in urgent need of these please for our product CE documentation.
Thanks in advance.
