I have a ESXi 7.0 U2 server and install Ubuntu 20.04 on it.
Intel ax210 has added to U20 and lspci can see it (Intel Corporation Device 2725(rev 1a)). When I tried install driver it showed some error in dmesg, and after that termial can't response to cmds that issued later.
See dmesg log below, please ignore the kernel version, this driver can run without issue on a laptop installed U20 directly.
I just want to confirm if intel ax210 can work in such way, any successful examples?
[ 253.165136] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 253.166054] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 253.170647] Intel(R) Wireless WiFi driver for Linux
[ 253.170648] Copyright(c) 2003- 2015 Intel Corporation
[ 403.440941] compat: loading out-of-tree module taints kernel.
[ 403.440957] compat: module verification failed: signature and/or required key missing - tainting kernel
[ 403.441673] Loading modules backported from iwlwifi
[ 403.441674] iwlwifi-stack-dev:common/Core62_WFA_R2_PF4:Linux_Core_build_19147:211d325039d6
[ 403.445290] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 403.445588] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 403.448877] Intel(R) Wireless WiFi driver for Linux
[ 403.459799] iwlwifi 0000:03:00.0: api flags index 2 larger than supported by driver
[ 403.459810] iwlwifi 0000:03:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.30
[ 403.460023] iwlwifi 0000:03:00.0: loaded firmware version 65.1eed1396.0 ty-a0-gf-a0-65.ucode op_mode iwlmvm
[ 403.477828] iwlwifi 0000:03:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[ 403.478982] thermal thermal_zone0: failed to read out thermal zone (-61)
[ 404.510357] iwlwifi 0000:03:00.0: SecBoot CPU1 Status: 0x85ca, CPU2 Status: 0xb03
[ 404.510385] iwlwifi 0000:03:00.0: UMAC PC: 0xc0080c98
[ 404.510405] iwlwifi 0000:03:00.0: LMAC PC: 0x4d08f2
[ 404.510409] iwlwifi 0000:03:00.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 404.758902] iwlwifi 0000:03:00.0: Start IWL Error Log Dump:
[ 404.758904] iwlwifi 0000:03:00.0: Transport status: 0x00000042, valid: 6
[ 404.758904] iwlwifi 0000:03:00.0: Loaded firmware version: 65.1eed1396.0 ty-a0-gf-a0-65.ucode
[ 404.758906] iwlwifi 0000:03:00.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[ 404.758906] iwlwifi 0000:03:00.0: 0x002002F0 | trm_hw_status0
[ 404.758907] iwlwifi 0000:03:00.0: 0x00000000 | trm_hw_status1
[ 404.758907] iwlwifi 0000:03:00.0: 0x004DA206 | branchlink2
[ 404.758908] iwlwifi 0000:03:00.0: 0x004D08F2 | interruptlink1
[ 404.758908] iwlwifi 0000:03:00.0: 0x004D08F2 | interruptlink2
[ 404.758909] iwlwifi 0000:03:00.0: 0x004D8FCC | data1
[ 404.758909] iwlwifi 0000:03:00.0: 0x01000000 | data2
[ 404.758910] iwlwifi 0000:03:00.0: 0x00000000 | data3
[ 404.758910] iwlwifi 0000:03:00.0: 0x00000000 | beacon time
[ 404.758911] iwlwifi 0000:03:00.0: 0x000E38E4 | tsf low
[ 404.758911] iwlwifi 0000:03:00.0: 0x00000000 | tsf hi
[ 404.758912] iwlwifi 0000:03:00.0: 0x00000000 | time gp1
[ 404.758912] iwlwifi 0000:03:00.0: 0x000F85D5 | time gp2
[ 404.758913] iwlwifi 0000:03:00.0: 0x00000001 | uCode revision type
[ 404.758913] iwlwifi 0000:03:00.0: 0x00000041 | uCode version major
[ 404.758914] iwlwifi 0000:03:00.0: 0x1EED1396 | uCode version minor
[ 404.758914] iwlwifi 0000:03:00.0: 0x00000420 | hw version
[ 404.758915] iwlwifi 0000:03:00.0: 0x18C89002 | board version
[ 404.758915] iwlwifi 0000:03:00.0: 0x8004FC12 | hcmd
[ 404.758916] iwlwifi 0000:03:00.0: 0x00020000 | isr0
[ 404.758916] iwlwifi 0000:03:00.0: 0x00000000 | isr1
[ 404.758917] iwlwifi 0000:03:00.0: 0x00F00002 | isr2
[ 404.758917] iwlwifi 0000:03:00.0: 0x00C0000C | isr3
[ 404.758918] iwlwifi 0000:03:00.0: 0x00000000 | isr4
[ 404.758918] iwlwifi 0000:03:00.0: 0x00000000 | last cmd Id
[ 404.758919] iwlwifi 0000:03:00.0: 0x004D8FCC | wait_event
[ 404.758919] iwlwifi 0000:03:00.0: 0x00000000 | l2p_control
[ 404.758920] iwlwifi 0000:03:00.0: 0x00000000 | l2p_duration
[ 404.758920] iwlwifi 0000:03:00.0: 0x00000000 | l2p_mhvalid
[ 404.758921] iwlwifi 0000:03:00.0: 0x00000000 | l2p_addr_match
[ 404.758921] iwlwifi 0000:03:00.0: 0x00000009 | lmpm_pmg_sel
[ 404.758922] iwlwifi 0000:03:00.0: 0x00000000 | timestamp
[ 404.758922] iwlwifi 0000:03:00.0: 0x001C0000 | flow_handler
[ 404.758969] iwlwifi 0000:03:00.0: Start IWL Error Log Dump:
[ 404.758970] iwlwifi 0000:03:00.0: Transport status: 0x00000042, valid: 7
[ 404.758971] iwlwifi 0000:03:00.0: 0x20000066 | NMI_INTERRUPT_HOST
[ 404.758971] iwlwifi 0000:03:00.0: 0x00000000 | umac branchlink1
[ 404.758972] iwlwifi 0000:03:00.0: 0x8045DB9E | umac branchlink2
[ 404.758972] iwlwifi 0000:03:00.0: 0x8047FB92 | umac interruptlink1
[ 404.758973] iwlwifi 0000:03:00.0: 0x8047FB92 | umac interruptlink2
[ 404.758973] iwlwifi 0000:03:00.0: 0x01000000 | umac data1
[ 404.758974] iwlwifi 0000:03:00.0: 0x8047FB92 | umac data2
[ 404.758974] iwlwifi 0000:03:00.0: 0x00000000 | umac data3
[ 404.758975] iwlwifi 0000:03:00.0: 0x00000041 | umac major
[ 404.758975] iwlwifi 0000:03:00.0: 0x1EED1396 | umac minor
[ 404.758976] iwlwifi 0000:03:00.0: 0x000F8AE1 | frame pointer
[ 404.758976] iwlwifi 0000:03:00.0: 0xC088625C | stack pointer
[ 404.758977] iwlwifi 0000:03:00.0: 0x00000000 | last host cmd
[ 404.758977] iwlwifi 0000:03:00.0: 0x00000400 | isr status reg
[ 404.759001] iwlwifi 0000:03:00.0: IML/ROM dump:
[ 404.759001] iwlwifi 0000:03:00.0: 0x00000B03 | IML/ROM error/state
[ 404.759012] iwlwifi 0000:03:00.0: 0x000085CA | IML/ROM data1
[ 404.759022] iwlwifi 0000:03:00.0: 0x00000090 | IML/ROM WFPM_AUTH_KEY_0
[ 404.759029] iwlwifi 0000:03:00.0: Fseq Registers:
[ 404.759032] iwlwifi 0000:03:00.0: 0x60000000 | FSEQ_ERROR_CODE
[ 404.759039] iwlwifi 0000:03:00.0: 0x80440003 | FSEQ_TOP_INIT_VERSION
[ 404.759042] iwlwifi 0000:03:00.0: 0x00080009 | FSEQ_CNVIO_INIT_VERSION
[ 404.759045] iwlwifi 0000:03:00.0: 0x0000A652 | FSEQ_OTP_VERSION
[ 404.759049] iwlwifi 0000:03:00.0: 0x00000002 | FSEQ_TOP_CONTENT_VERSION
[ 404.759052] iwlwifi 0000:03:00.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 404.759055] iwlwifi 0000:03:00.0: 0x00400410 | FSEQ_CNVI_ID
[ 404.759058] iwlwifi 0000:03:00.0: 0x00400410 | FSEQ_CNVR_ID
[ 404.759061] iwlwifi 0000:03:00.0: 0x00400410 | CNVI_AUX_MISC_CHIP
[ 404.759066] iwlwifi 0000:03:00.0: 0x00400410 | CNVR_AUX_MISC_CHIP
[ 404.759072] iwlwifi 0000:03:00.0: 0x00009061 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 404.759077] iwlwifi 0000:03:00.0: 0x00000061 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 404.759080] iwlwifi 0000:03:00.0: Failed to start RT ucode: -110
[ 404.759081] iwlwifi 0000:03:00.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 405.006385] BUG: kernel NULL pointer dereference, address: 000000000000002d
[ 405.006386] #PF: supervisor read access in kernel mode
[ 405.006386] #PF: error_code(0x0000) - not-present page
[ 405.006387] PGD 0 P4D 0
[ 405.006388] Oops: 0000 [#1] SMP NOPTI
[ 405.006390] CPU: 0 PID: 6853 Comm: modprobe Tainted: G OE 5.4.0-42-generic #46-Ubuntu
[ 405.006390] Hardware name: VMware, Inc. VMware Virtual Platform/440BX Desktop Reference Platform, BIOS 6.00 11/12/2020
[ 405.006401] RIP: 0010:iwl_mvm_start_get_nvm+0xac/0x190 [iwlmvm]
[ 405.006402] Code: 41 89 c4 85 c0 74 18 3d 7c ff ff ff 74 11 48 8d bb c8 0e 00 00 be 11 00 00 00 e8 bf f5 ec ff 48 8b 83 b0 0d 00 00 48 8b 53 18 <0f> b6 48 2d 48 8b 43 10 48 8b 80 e0 00 00 00 48 d1 e8 83 e0 01 83
[ 405.006402] RSP: 0018:ffffaffb4062fb40 EFLAGS: 00010287
[ 405.006403] RAX: 0000000000000000 RBX: ffff9373af4227a8 RCX: 0000000000000000
[ 405.006404] RDX: ffffffffc09b8b80 RSI: 0000000000000000 RDI: 000000000016ab3f
[ 405.006404] RBP: ffffaffb4062fb58 R08: 0000008e4f565ad7 R09: 0000000000000000
[ 405.006404] R10: 0000000000000000 R11: 0000000000000001 R12: 00000000ffffff92
[ 405.006405] R13: ffff9373af4227d8 R14: 0000000fffffffe0 R15: ffff9373af4227a0
[ 405.006406] FS: 00007f349f828540(0000) GS:ffff9373bba00000(0000) knlGS:0000000000000000
[ 405.006406] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 405.006407] CR2: 000000000000002d CR3: 0000000063ea6005 CR4: 0000000000760ef0
[ 405.006428] PKRU: 55555554
[ 405.006429] Call Trace:
[ 405.006436] iwl_op_mode_mvm_start+0x875/0xa40 [iwlmvm]
[ 405.006442] _iwl_op_mode_start.isra.0+0x47/0x80 [iwlwifi]
[ 405.006445] iwl_opmode_register+0x79/0xd0 [iwlwifi]
[ 405.006447] ? 0xffffffffc07cd000
[ 405.006451] __init_backport+0x3f/0x1000 [iwlmvm]
[ 405.006452] ? 0xffffffffc07cd000
[ 405.006455] do_one_initcall+0x4a/0x1fa
[ 405.006456] ? kfree+0x231/0x250
[ 405.006459] ? _cond_resched+0x19/0x30
[ 405.006459] ? kmem_cache_alloc_trace+0x16c/0x240
[ 405.006461] do_init_module+0x62/0x250
[ 405.006462] load_module+0x10b8/0x1200
[ 405.006464] __do_sys_finit_module+0xbe/0x120
[ 405.006465] ? __do_sys_finit_module+0xbe/0x120
[ 405.006466] __x64_sys_finit_module+0x1a/0x20
[ 405.006467] do_syscall_64+0x57/0x190
[ 405.006468] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 405.006469] RIP: 0033:0x7f349f96d70d
[ 405.006470] Code: 00 c3 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 53 f7 0c 00 f7 d8 64 89 01 48
[ 405.006471] RSP: 002b:00007fff604f3638 EFLAGS: 00000246 ORIG_RAX: 0000000000000139
[ 405.006471] RAX: ffffffffffffffda RBX: 000055a91c6abdd0 RCX: 00007f349f96d70d
[ 405.006472] RDX: 0000000000000000 RSI: 000055a91c00c358 RDI: 0000000000000002
[ 405.006472] RBP: 0000000000040000 R08: 0000000000000000 R09: 0000000000000000
[ 405.006473] R10: 0000000000000002 R11: 0000000000000246 R12: 000055a91c00c358
[ 405.006473] R13: 0000000000000000 R14: 000055a91c6abee0 R15: 000055a91c6abdd0
[ 405.006474] Modules linked in: iwlmvm(OE+) mac80211(OE) libarc4 iwlwifi(OE) cfg80211(OE) compat(OE) nls_iso8859_1 crct10dif_pclmul ghash_clmulni_intel aesni_intel vmw_balloon crypto_simd cryptd glue_helper joydev input_leds serio_raw vmwgfx ttm drm_kms_helper fb_sys_fops syscopyarea sysfillrect vmw_vmci sysimgblt mac_hid sch_fq_codel parport_pc ppdev lp parport drm ip_tables x_tables autofs4 hid_generic usbhid hid crc32_pclmul psmouse mptspi vmxnet3 mptscsih mptbase ahci libahci scsi_transport_spi i2c_piix4 pata_acpi [last unloaded: cfg80211]
[ 405.006491] CR2: 000000000000002d
[ 405.006492] ---[ end trace 95b88db1ed32ad8d ]---
[ 405.006497] RIP: 0010:iwl_mvm_start_get_nvm+0xac/0x190 [iwlmvm]
[ 405.006497] Code: 41 89 c4 85 c0 74 18 3d 7c ff ff ff 74 11 48 8d bb c8 0e 00 00 be 11 00 00 00 e8 bf f5 ec ff 48 8b 83 b0 0d 00 00 48 8b 53 18 <0f> b6 48 2d 48 8b 43 10 48 8b 80 e0 00 00 00 48 d1 e8 83 e0 01 83
[ 405.006498] RSP: 0018:ffffaffb4062fb40 EFLAGS: 00010287
[ 405.006498] RAX: 0000000000000000 RBX: ffff9373af4227a8 RCX: 0000000000000000
[ 405.006499] RDX: ffffffffc09b8b80 RSI: 0000000000000000 RDI: 000000000016ab3f
[ 405.006499] RBP: ffffaffb4062fb58 R08: 0000008e4f565ad7 R09: 0000000000000000
[ 405.006500] R10: 0000000000000000 R11: 0000000000000001 R12: 00000000ffffff92
[ 405.006500] R13: ffff9373af4227d8 R14: 0000000fffffffe0 R15: ffff9373af4227a0
[ 405.006501] FS: 00007f349f828540(0000) GS:ffff9373bba00000(0000) knlGS:0000000000000000
[ 405.006501] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 405.006501] CR2: 000000000000002d CR3: 0000000063ea6005 CR4: 0000000000760ef0
[ 405.006518] PKRU: 55555554
链接已复制
Hello zujl,
Thank you for posting in the Intel Communities. We understand that you are having issues when setting the AX210 on your server running ESXi 7.0 U2 with Ubuntu 20.04; we would be more than glad to help you with your problem.
We will look further into this scenario and reply once we have more details.
Jean O.
Hello zujl,
Thanks for your patience.
We understand that you previously mentioned that the driver can work without an issue with this Kernel version, however, we would like to recommend you update to the latest Kernel version available.
Jean O.
Sorry for the late reply.
The kernel that I mentioned works well is on a laptop installed with Ubuntu directly, not a Ubuntu virtual machine on ESXi host.
I tried with kernel 5.15 on ESXi host virtual machine with ubuntu 20.04.6 to see if default driver can support intel ax210 but it also showed such messages and can't see intel ax210 interface with ifconfig -a. See attached logs.
So I'm not sure if intel ax210 can support work in such way or I need some configuration to get it work?
Hello zujl,
We appreciate your patience.
As you are experiencing an issue within a virtual environment on the Ubuntu operating system, we suggest reaching out to your Hypervisor for additional assistance.
Jean O.
Hello zujl,
We're glad to know the information helped. Hopefully, it will help other community members. Since we recommended contacting Hypervisor support, we will close this thread now. If you need additional information, please submit a new question since this thread will no longer be monitored.
Jean O.
