- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
hi, i tried different kernel & firmware on ubuntu , eht is seen, but no mlo founded.
Does the ubuntu support MLO with be200 ?
Those are combinations i have tried:
driverversion=6.8.0-45-generic firmware=83.ec13314b.0 gl-c0-fm-c0-83.uc ---- eht + no_ml
driverversion=6.8.0-45-generic firmware=86.fb5c9aeb.0 gl-c0-fm-c0-86.uc ---- eht + no_ml
driverversion=6.10.1-061001-generic firmware=86.fb5c9aeb.0 gl-c0-fm-c0-86.uc ---- eht + no_ml
driverversion=6.10.1-061001-generic firmware=90.38c93dbc.0 gl-c0-fm-c0-90.uc ---- he
driverversion=6.11.0-061100-generic firmware=90.38c93dbc.0 gl-c0-fm-c0-90.uc ---- he
driverversion=6.11.0-061100-generic firmware=92.67ce4588.0 gl-c0-fm-c0-92.uc ---- he
Device info
*-network
description: Ethernet interface
product: Wi-Fi 7(802.11be) AX1775*/AX1790*/BE20*/BE401/BE1750* 2x2
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:01:00.0
logical name: wlp1s0f0
version: 1a
serial: 10:91:d1:52:61:47
width: 64 bits
clock: 33MHz
capabilities: bus_master cap_list ethernet physical
configuration: broadcast=yes driver=iwlwifi driverversion=6.11.0-061100-generic firmware=90.38c93dbc.0 gl-c0-fm-c0-90.uc ip=192.168.1.101 latency=0 link=yes multicast=yes
resources: irq:16 memory:74200000-74203fff
- Marcas:
- MLO
Link copiado
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello nlee,
I understand that you're looking forward to know if Linux kernel 6.11 supports MLO with be200. I do not have an answer at this moment but I’ll investigate it and contact you back as soon as possible.
Jed G.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi nlee,
I'm following up to the investigation that I had conducted. Based on my research, Intel® Wi-Fi 7 products support the 6GHz band for Wi-Fi. Usage of the 6GHz band relies on Operating System support as stated in the bullet.
- Wi-Fi 7 features are depended on Kernel, Operation System support and connected Access Point (router) – Wi-Fi 7 functionally may be limited.
Also, could you please share the following information?
- Is this a self-integration, hardware OS supported Linux?
- AP and ISP supported and was this hardware able to access 6GHz before?
I hope to hear from you soon.
Jed G.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello nlee,
I wanted to check if you had the chance to review the questions and information I posted. Please let me know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Jed G.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello nlee,
Jed G.
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
