Wireless
8611 Discussions
Does the AX200 Wi-Fi6 adapter has the support for monitor mode
BGopu
AX200 wi-fi6 adapter
LeonWaksman
Please read the Experience the Intel Difference section, I correctly understand, the monitor mode is supported in both: Pre-Boot environment and in Windows environment: https://www.intel.com/content/dam/www/public/us/en/documents/product-briefs/wi-fi-6-ax200-module-brief.pdf
Leon
BGopu
Can i capture the beacon frames of surrounded APs using the AX200 Wi-Fi6 adapter
AdrianM_Intel
Hello BGopu,
Thank you for posting on the Intel® communities.
In regards to your second question, I will further investigate this please allow me some time to get back to you.
Adrian M.
A Contingent Worker at Intel
BGopu
Sure Adrianx. Thanks for response.
AdrianM_Intel
Hello BGopu,
I would like to update the thread.
That feature is not supported on Windows if you want to confirm or review what features are supported you can run the netsh commands for instance: netsh wlan show wirelesscapabilities
For Linux depending on the Linux driver it will be supported but for more details about Linux drivers, we recommend you to contact Linux support in case you want to use confirm it.
Adrian M.
IFuXwiTuZ
I just wanted to say Intel Whatever customer service provider you guys are a bunch of n00bs
en:users:drivers:iwlwifi [Linux Wireless] (kernel.org)
im assuming you need this to work for sniffing so here you go
