Wireless
8697 Discussions
Drivers for Intel Dual Band Wireless-AC 7260 Card?
SSyno
Just put a new system together and installed an Intel Dual Band Wireless-AC 7260 in it. Used Windows 8 Pro. x64. I cannot find drivers for the Intel Dual Band Wireless-AC 7260.
Anyone know where I can get drivers for this card? I purchased the card from Provantage.
Jose_H_Intel1
Hello Synomenon,
The drivers will be released soon; this is because the product has not been officially released yet.
DElli7
The software works, but the Device Manager is not able to find the Bluetooth hardware. It finds the Network Device, just fine, but no Bluetooth.
Can anyone give me a step-by-step instruction to manually locate the driver to activate the integrated Bluetooth device within the card?
BBrad4
When I tried to use the Intel drivers on Win7, Bluetooth is the only thing that worked and installed. The device manager found the hardware and did what it's supposed to do.
Perhaps Intel mixed up the driver build by providing the AC 7260 driver for Win8 and the Bluetooth for Win7. Whatever Intel needs drivers for both Win7 and Win8 that work.
DElli7
I attempted to load both a Win 7 & Win 8 Bluetooth driver for the AC7260 and unfortunately...nothing. At least the Wi-Fi portion of the AC7260 is working.
Has anyone been able to solve the Bluetooth issue for the AC7260 in Win 8 Pro x64? I'd hate to buy a USB nano Bluetooth adapter until a resolution has been found.
Thanks very much.
BHart4
Sager Notebooks has posted a new Windows 7 and Windows 8 driver(both are same driver) for the AC-7260.The driver version is 16.1.0.14
http://www2.sagernotebook.com/pages/notebooks/download.cfm?ProductType=9380 http://www2.sagernotebook.com/pages/notebooks/download.cfm?ProductType=9380
The driver works on 3 different notebooks that I tried it on>MSI,LG,Samsung
The driver supports both 32bit and 64bit versions of XP,Vista,W7,W8 and Windows 8.1 Preview.
LT1
In Re: Bluetooth for Windows 8 -- my AC7260 card loaded Intel (and Microsoft's) driver just fine, in both Win 7 and Win 8. Perhaps your laptop has BT switched off? My Acer laptop lets you enable Bluetooth separate from WiFi via the Fn key... just a thought.
LT1
@ SmogHog -- thanks for chiming in with that. You are correct, that file does include Win7 and Win8 drivers for x32/x64. Heck, it even includes XP x32 and x64 drivers. Intel does in fact deliver.... even if they took a while. Brand-spanking new, too.. The date on the *.sys driver files is July 11, 2013.
NV3
does anyone else find it ridiculous that we have to rely on a computer manufacturer to release a driver before intel?
ROwen2
Ridiculous that Linux drivers are out before Windows 7... Although I use Linux A LOT more then Windows I still need Wireless to work in Windows...
Working on my HP DV6T-7000 with Windows 7 HP 64bit. Bluetooth works out of the box...
Now I wonder why the connection speed in Windows is faster then in Linux...
From 295 Mb/s to 120 MB/s...
BBrad4
Works great for both ac wireless and bluetooth on the Dell XPS with Win7. You'd think Intel would make them available for download.
jlort1
Installed this card in two Dell XPS 12s, neither has Bluetooth now. I have no toggles to turn BT on and off. Wifi works. Reinstall the 6235, BT is back. Any ideas? BT doesn't show in device manager with the ac 7260.
DQuir1
I am starting to think a couple of things about intel not releasing drivers for these cards.. and us finding drivers from sites like sager and clevo..
1. ether these cards are bad,,,
or
2, the drivers are bad and these cards were released well ahead of scheadule..
I have an Alienware m18x-r2 and it has the killer 1103 in it and with my asus rt-ac66r(wich is the same as the 66u)
i get a steady 450MB connection with file transfers at and exceeding 40MB/sec
With my ac7260 card i dont get any where near that speed..it is all over the board... never holds a continuous speed..
have i seen the higher speeds that are advertised for this card.. sure i have... but it will not hold them and upon any activity it drops... so i.e. it will go say 720mb/sec .. then i start some thing it will drop to 150..200... 350...300...195...139... and so forth.. but at idle right now it sits at 300mb/sec
I am disapointed that these forums and message boards are never really responded to by intel employies...
well please intel,drop us some words of wisdom about this issue please.. and some drivers! that work properly!
PSmit14
I am pretty much in the same boat but with an Acer with Win 7. I have tried uninstalling and reinstalling 7 ways from Sunday with no luck(or Bluetooth). But if I plug in a Bluetooth dongle, not a problem.
PSmit14
I'm having issues with my Acer, the computer kind of just stops working, the 2.4Ghz WiFi drops and then comes back and then everything starts working again.
I'm about ready to put my 6200 back in. The range on these 7260's don't seem to be all that great, with the old card I could cover the whole house on 5Ghz at 300Mbps, with these 7260's I'm lucky to get half that speed.
BBrad4
The sager Win7 drivers works fine on my 1702 XPS and my speed is at a consistent 866.7. The only thing I did differently was that I tried to install the Win8 drivers found on the intel site. The only thing that worked with the Win8 drivers was the bluetooth. I didn't pay too much attention during the sager driver install but both the wireless and bluetooth work fine. It might be worth a try to get the bluetooth working.
jlort1
Bluetooth DOESNT show in Device manager. Nothing, not even unknown device.
ROwen2
Perhaps you got a bad card?
If you have devcon installed you can get some more detailed information:
devcon listclass net
jlort1
Maybe a bad lot. I purchased 2, neither showed bt. Wifi signal bounced all over the place. Both laptops are Dell XPS 12s, ivy bridge i5s. Using win8 64 bit intel drivers.
ROwen2
Sorry to hear that. I got mine from Amazon. Bluetooth and wireless seem to work on both win 7 and Diamond II-B. But, like what has been stated before, I cannot get speed past 300 Mb/s. Linux is stuck at 150 Mb/s. Hate that..
I would take a look at the devcon output. Just to check.
wface
I got mine from compsource. No issues that I know of with it. I don't use and have bluetooth disabled on my laptop so I can't say if it works or not. I would tend to think you're right about a bad lot. This being new, it's entirely possible Intel hasn't worked out all the manufacturing kinks yet.
jlort1
Do you show Bluetooth in device manager?
wface
I'm using Debian Linux so don't have Device Manager. However, I'll put the card back in and check to see if Bluetooth works.
