Wireless
8617 Discussions
Enabling WOWLAN on 4965AGN
jcart10
Hi, I have an Alienware M9750 with an Intel 4965AGN wireless card. I want to use WOWLAN, but under the Power Management tab in the properties window for the card, "Allow this device to wake the computer" is grayed out and under the Advanced tab, there is no Wake-Up Capabilities option. I thought WOWLAN was supported on this card. I know that the newest driver removed support for it, and I'm not sure why, but I tried a few other earlier drivers with no luck. Any ideas? Thank you.
It was decided to remove WOWLAN support in the new SW generation.
jcart10
I understand that support was removed in later drivers. Thats why I am wondering if there are earlier drivers that have support for it... And are you sure you are talking about the same card I am; it is not a new card. I got the laptop 3 years ago.
Yes. I am talking about the same card 4965 adapter. As mentioned above. WoWLAN is not a supported feature in the newer software releases across all adapters. If you want this feature you might want to roll back to old 12.4.x releases if still available.
jcart10
I've already tried earlier drivers including some 12.4.x.
If you tried 12.4.0 release and the feature is not working then:
1) You need to be connected to Legacy A/G AP in order for the feature to work. WoWLAN won't function if you are connected to 11n AP.
2) Your machine has to support this feature. Sometimes there is an option to enable/disable this feature in the bios. you might want to check that.
3) if the feature is still not working then most probably your machine doesn't support it.
jcart10
Could you explain Legacy A/G vs 11n? I have wolan enabled in bios and had it enable through my ethernet connection. Thank you for your help.
