Wireless
8529 Discussions
Error 2732
womack49er
When trying to install update on Killer Performance Driver Suite UWD. I get "Killer Performance Driver Suite UWD cannot be installed with Killer Wireless Drivers. Error 2732. I do not mind skipping an update. I just see that red dot intel icon and I want it back to normal.
womack49er
First I would like to personally Thank You for looking over my problem. I appreciate your time and effort.
1. Were you able to install the previous driver without any issues? Yes I had other updates. I installed the Intel Driver and Support app. It had been uninstalled for IDK Months. I had a few updates but it installed all but one.
2. Is this a laptop or a desktop system? Windows 11 Desktop Dell XPS 8960
3. Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently? I believe it is the original.
4. Have you performed if any troubleshooting steps? If yes, kindly share it with me. I installed drivers and unplugged my modem. Tried to update then with the downloaded package.
JedG_Intel
Hello womack49er,
For me to properly address your concern, please share the information below.
Best regards
Jed G.
womack49er
JedG_Intel
Hello womack49er,
Thank you for sharing all this information.
For further troubleshooting, please try to follow the outlined steps below.
  • Uninstall Killer™ Control Center if it was been installed before installed Killer™ Performance Suite.
  • Download the latest version of the Intel® Killer™ Performance Suite.
  • Turn off Wi-Fi and remove the network cable.
  • Open Device Manager, right click the adapter, click Uninstall Device.
  • Right click the adapter, click Uninstall Device.
  • Install Intel Killer Performance Suite.
For reference: Encountered Error: "Error 2732 Directory Manager not Initialized" when Installing Intel® Killer™ Performance Suite
If you continue to encounter the same issue, please let me know.
Best regards
Jed G.
womack49er
It worked but it did get a cannot install with  Killer Ethernet so I deleted it too. That did the trick. Thank You
JedG_Intel
Hello womack49er,
I'm glad to hear that the recommendations did help. Since the inquiry has been address, I will proceed with closing this thread.
Should you have other questions, please submit a new thread as this one will no longer be monitored.
Best regards
Jed G.
