- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
Link copiado
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello XAim0
Regarding error code 10 in Device Manager, there are some steps we can try to see if the problem is solved. Please check the below recommendations:
- Perform a cold reboot (hold the power button until the system powers off).
- For laptops, reseat the battery if possible (remove and reinstall). Please refer to your system manufacturer for guidance.
- Perform a Clean Installation of Wireless Drivers and reboot the computer. We recommend you install the wireless driver customized for your specific system model and provided by your Original Equipment Manufacturer (OEM, ASUS*). You can download the driver from the following link, please make sure you select your specific system model to download the proper driver: Intel® Wireless LAN driver Version V21.50.0.5*.
- Try a hard shut down, wait for a couple of minutes and turn on the computer.
- Load BIOS defaults. Please refer to your system manufacturer for guidance for settings/updates before trying this step.
If the issue persists, we recommend checking with the OEM of your system (ASUS* support) for additional suggestions and to discard the possibility of a hardware problem. List of Computer Manufacturer Support Websites.
Andrew G.
*Links to third-party sites and references to third-party trademarks are provided for convenience and illustrative purposes only. Unless explicitly stated, Intel® is not responsible for the contents of such links, and no third party endorsement of Intel® or any of its products is implied.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello XAim0
We are checking this thread and we would like to know if you were able to perform the steps recommended in our previous post. Does the issue persist? If yes, were you able to contact your OEM?
Andrew G.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello XAim0
We have not heard back from you so we will be proceeding to close this thread soon. If you have additional inquiries please do not hesitate to contact us back.
Andrew G.
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
