Wireless
8521 Discussions
I cannot use the WiFi7 function
honker
I am using the latest driver 23.150.0.4 for the be200 network card, but I cannot use the wifi7 function. After connecting to a wifi7 network, it only displays wifi6. My computer system is win11 24h2.
honker
我的骁龙8Lite处理器手机,连接同一个WiFi 7网络,可以正常使用。
honker
My Snapdragon 8Lite processor phone can be used normally when connected to the same WiFi 7 network.
Mike_Intel
Hello honker,
  1. What is the brand and model of your system?
  2. Was it working fine before?
  3. If yes, what was the last change made before the issue started?
  4. Can you provide some screenshots of the issue?
  5. Let me also check, did you manually install the BE200 as an upgrade or this is embedded in your system?
  6. For me to review the hardware and the driver installed, please help generate the SSU logs of your system. Please refer to the link below on how to generate the logs:
Michael L.
honker
  2. It wasn't normal before either
  4. manually install the BE200
Mike_Intel
Hello honker,
Thank you for the update.
Based on the screenshot I believe the manufacturer of your system/laptop is Asus?
Have you tried contacting Asus for further checking the compatibility and configuration?
The reason why I asked is because Intel have a regulatory document that you need to check this first with the system manufacturer.
Please refer to the link below for the regulatory information.
Regulatory Information Regarding Wireless Hardware Installation or...
Michael L.
honker
It's an ASUS ROG laptop. I don't think it's an ASUS issue, as this isn't an isolated case but a common problem. Many users on Chinese online forums have reported that the Wi-Fi 7 functionality stops showing up after the driver version 23.30.0, although it was previously available. Reinstalling the system and rolling back to this specific driver version can restore the functionality.
Mike_Intel
Hello honker,
I am not saying that it is an Asus issue, kindly read the regulatory information for more details on why I am asking if you tried contacting Asus first.
Possible causes are compatibility and configuration with the system since this is a manual install hardware as an upgrade.
Michael L.
Mike_Intel
Hello honker,
I am just making a follow up to check if your also tried to contact the manufacturer of the system.
And also let me add, while reviewing the information that you provided, let me provide the following details as well.
Please try updating the wireless driver to version 23.160.0 (latest) using our generic driver version, because you are currently using version 23.150.0.4, which is outdated. If the issue persists, please try using the OEM driver, version 22.130.0.5.
Michael L.
honker
I have updated to version 23.160.0, but the issue persists, and I am unable to revert to version 22.130.0.5, as it indicates that a newer version is already installed.
honker
The policy of Chinese Mainland is to ban the 6ghz frequency band, while other wifi7 features are normal, which is why my mobile phone can connect to wifi7 normally.
Mike_Intel
Hello honker,
At this point since we already tried the generic driver from Intel and OEM driver, it is best to contact Asus for further checking the compatibility and configuration since you manually installed the wireless controller.
Michael L.
Mike_Intel
Hello honker,
Michael L.
honker
Asus customer service said that the motherboard does not support it, but I think they are just perfunctory because this laptop only supports WiFi 5 natively, and they also said they do not support WiFi 6. But obviously, I can use WiFi 6 normally after installing BE200.
Mike_Intel
Hello honker,
I think that is the problem there, the system itself cannot support Wi-Fi 6, and you are trying to install this card. Please also understand that the compatibility and also the functionality of the card will now depend on the systems capability. That is why we provided the Regulatory link to check everything first with the system manufacturer to avoid issues like this before upgrading. Here is the link again.
Michael L.
