Wireless
8787 Discussions
Intel 20.110.0 Wifi driver spams Windows logs, wakes up modern standby every 10 minutes
HKlum
Valued Contributor I
Intel 20.110.0 Wifi driver for 9260 is totally broken, not usre if previous was already broken. It spams these Windows event logs and wakes up modern standby every 10 minutes:
https://i.imgur.com/HfsnR0v.png
7025 - Dump after return from D3 before cmd
7026 - Dump after return from D3 after cmd
7021 - Connection telemetry fields and analysis usage
Der verbundene Standbymodus wird beendet.
Das System wechselt in den verbundenen Standbymodus.
6062 - Lso was triggered
This causes over 140000 NTFS file events too in 2 hours:
https://i.imgur.com/3V863bF.png
Leonardo_C_Intel
Hello HKlum Thank you for posting in the Intel Community. I am noticing that you have reported the standby behavior on the community Intel 20.110.0 BT driver causes modern standby drain and we are assisting you with this behavior on that community; we are going to continue the assistance there. Hope this helps. Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation
Leonardo_C_Intel
