Wireless
8899 Discussions
Intel 4965 AGN MM2
i recently upgraded my intel 3945 ABG with the intention of getting better performance from the newer card. i upgraded to intel 4965 AGN MM2 and to my surprise my 5 ghz network wasn't detected. i currently use either channel 149 or 153 for my 5 ghz 20 mhz network because there is another router in channel 42 or 44. i have the most current driver which is 13.4.0.139 and dated 10/7/2010. i have googled for about two days with no solution until i figured i'd try intel community. the only solution i found in order to use my 5 ghz network is to use channels 36-52 but channels 149-165 are not detected no matter what. i am hoping to get one answer from this post. is the intel 4965 agn mm2 card limited to some channels?
PS my intel 3945 is able to see channels 149-157...5
Compaq Presario v6700
Windows XP SP3 lastest updates
Victor_B_Intel
Thank you very much for your post Luis.
We understand that you have some questions on regards to the
Note that the Intel® Wireless WiFi Link 4965 AGN wireless adapter is meant to be professionally installed by Original Equipment Manufacturer (OEM) technicians on certified systems only.
On regards to this adapter it is not meant to be sold separately, also your system must be compliant with the required FCC certifications in compliance with the International Special Committee for Radio Interference standards for radiated and conducted electromagnetic interference.
As per the description of your issue, we would recommend you contacting the Original Equipment Manufacturer (Compaq*) to determine if this product is approved for use in your computer.
You may contact Compaq* Technical support at the following link:
http://www.compaq.com/cpq-country/cpq_support.html Compaq - Support for Presario notebooks and desktops.
NOTE: This link is being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
For additional information, refer to:
Intel® WiFi Products - Upgrade or exchange Intel® wireless adapter hardware.
http://www.intel.com/support/wireless/wlan/sb/CS-006006 http://www.intel.com/support/wireless/wlan/sb/CS-006006
Intel® WiFi Products - Why doesn't my laptop recognize my new Intel wireless adapter?
http://www.intel.com/support/wireless/wlan/sb/CS-031167.htm http://www.intel.com/support/wireless/wlan/sb/CS-031167.htm
Regards!
