Wireless
8536 Discussions
Intel 7260 Code 10 after installing lastest drivers on win8.1 ( 17.0.6.1)
JSmyt1
15 955 Visites
I recently got a Intel 7260 mini pci card and once installed it allways comes up with windows errror code 10.
The drivers are the lastest , 17.0.6.1 released a few days ago.
I'm using a dell 1537 running Win 8.1 with the lastest bios.
i have dug further. windows logs gives a few errors
Intel(R) Dual Band Wireless-AC 7260 : The version number is incorrect for this driver.
and
Intel(R) Dual Band Wireless-AC 7260 : Could not allocate the resources necessary for operation.
The device ID is
PCI\VEN_8086&DEV_08B2&SUBSYS_42708086&REV_4B\4&B04CCE1&0&00E1
0 Compliments
32 Réponses
Kevin_M_Intel
Employé
6 721 Visites
Hi Delphian,
Let me help you with this.
Thanks for the information. There is still some more information I would like to get from the computer so I can have a clear picture of the issue.
Are you getting the error code from device manager? Have you tried another troubleshooting step?
Can you also please add your dxdiag report here?
How to get it?
Dxdiag Report: Type dxdiag in Start Menu> open> Save> Copy/Paste here.
Kevin M
0 Compliments
JSmyt1
6 721 Visites
The erors i got came from the event history i'll do a dxdiag tonight as its 7am here now ( i have to swap out my wifi card and put the intel one back in )
0 Compliments
JSmyt1
6 721 Visites
Ok i have installed ubunto and the intel 7260 works fine so its not faulty either my copy of windows is screwed or the drivers are not behaving. i suspect the drivers as the install of windows is only a recent install
dx diag came up with
System Information
Time of this report: 8/21/2014, 21:59:13
Machine name: JUSTINSLAPTOP
Operating System: Windows 8.1 Pro 64-bit (6.3, Build 9600) (9600.winblue_gdr.140330-1035)
Language: English (Regional Setting: English)
System Manufacturer: Dell Inc.
System Model: Studio 1537
BIOS: Ver 1.00 BIOS A11 PARTTBL"
Processor: Intel(R) Core(TM)2 Duo CPU P8400 @ 2.26GHz (2 CPUs), ~2.3GHz
Memory: 4060MB RAM
Available OS Memory: 4060MB RAM
Page File: 1645MB used, 3119MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.03.9600.16384 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: ATI Mobility Radeon HD 3400 Series (Microsoft Corporation - WDDM v1.1)
Manufacturer: Advanced Micro Devices, Inc.
Chip type: ATI display adapter (0x95C4)
DAC type: Internal DAC(400MHz)
Device Type: Full Device
Device Key: Enum\PCI\VEN_1002&DEV_95C4&SUBSYS_029F1028&REV_00
Display Memory: 2042 MB
Dedicated Memory: 250 MB
Shared Memory: 1792 MB
Current Mode: 1280 x 800 (32 bit) (59Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: SEC5441
Native Mode: 1280 x 800(p) (59.952Hz)
Output Type: Internal
Driver Name: aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atiumdag,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Driver File Version: 9.18.0010.1129 (English)
Driver Version: 8.97.10.6
DDI Version: 10.1
Feature Levels: 10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.1
Graphics Preemption: DMA
Compute Preemption: DMA
Miracast: Not Supported
Hybrid Graphics GPU: Not Applicable
Power P-states: Not Applicable
Driver Attributes: Final Retail
Driver Date/Size: 4/25/2013 23:28:10, 1103904 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B71EE2-D684-11CF-F177-9522BDC2C435}
Vendor ID: 0x1002
Device ID: 0x95C4
SubSys ID: 0x029F1028
Revision ID: 0x0000
Driver Strong Name: oem4.inf:cb0ae4144264b8e2:ati2mtag_M72:8.97.10.6:pci\ven_1002&dev_95c4
Rank Of Driver: 00DE2001
Video Accel: ModeMPEG2_A ModeMPEG2_C
DXVA2 Modes: DXVA2_ModeMPEG2_IDCT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeVC1_VLD
Deinterlace Caps: {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
D3D9 Overlay: Not Supported
DXVA-HD: Not Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Speakers (High Definition Audio Device)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_111D&DEV_7675&SUBSYS_1028029F&REV_1001
Manufacturer ID: 1
Product ID: 65535
Type: WDM
Driver Name: HdAudio.sys
Driver Version: 6.03.9600.16384 (English)
WHQL Logo'd: n/a
Date and Size: 8/22/2013 21:38:21, 395776 bytes
Other Files:
Driver Provider: Microsoft
HW Accel Level: Basic
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
Description: Microphone (High Definition Audio Device)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x0
Format Flags: 0x0
Video Capture Devices
Number of Devices: 1
FriendlyName: Integrated Webcam
SymbolicLink: \\?\usb# vid_0c45&pid_63fa&mi_00# 6&76f3a0e&0&0000# {e5323777-f976-4f5b-9b55-b94699c46e44}\global
Manufacturer: Creative Technology Ltd.
HardwareID: USB\VID_0C45&PID_63FA&REV_8908&MI_00,USB\VID_0C45&PID_63FA&MI_00 ...
0 Compliments
BB4
Nouveau contributeur II
6 721 Visites
As many of us using Windows 7 have discovered, current versions of the drivers have have caused all kinds of issues.
Try an early v 16. driver and see what happens. I went back to 16.10 and now the card actually works.
0 Compliments
JSmyt1
6 721 Visites
No Luck with 16.10 , will try with 16.7 and a few below.
0 Compliments
BB4
6 721 Visites
Wait, something's not right here. That device ID is funny. I can't find 08B2 as an Intel part. According to pcidatabase.com, Device 0x08b2 is the Logitech QuickCam Pro 4000.
0 Compliments
JSmyt1
6 721 Visites
Thats what i get .
the card works as a intel Dual Band AC 7260 in ubuntu V14.
*** this web site indicates its Right
http://www.driveridentifier.com/scan/intelr-dual-band-wireless-n-7260/driver-detail/9C0CEBB756EC44A484EDE85E9210AB80/1568499/1d35fcb5feedee69a5b145ee30e16a38/1389358735/PCI%5CVEN_8086%26DEV_08B1%26SUBSYS_40608086 Intel(R) Dual Band Wireless-N 7260 Driver Download for WIN7,WIN8/64bits - Acer Aspire V7-582PG (Type1Family/TBD by OEM- …
0 Compliments
BB4
6 721 Visites
So it is.
The card works in ubuntu, so bad card is out.
Gotta be that you haven't hit the right driver yet. Keep trying the 16s.
0 Compliments
JSmyt1
6 721 Visites
Kevin , maybe the engineers could make a driver that gives more details on the errors ?
0 Compliments
HDhal1
6 721 Visites
Having the same issue, with win 8 and 8.1 . Have 5 ac7260 cards on hand, and all give code 10.
0 Compliments
JSmyt1
6 721 Visites
The best thing to do is look at the event viewer , it shows more info with the latest drivers.
The next version of the drivers need to show alot more debug info , whats failing etc. i suspect something to do with allocating resources is wrong. i've even checked in ubuntu as to what resources are in use and ( Memory IRQ Etc) and checked in windows and it shows no conflicts.
if intel dont fix this , as a contractor for many business in my area i will advise NOT to use intel products for Wifi and use broadcom instead ( I've ordered a broadcom card aswell , because the drivers from intel are full of crap)
0 Compliments
JSmit97
Débutant
6 467 Visites
My AC 7260 Dual Band Wireless quit working, said can't load driver, code 10. I fought this on two occasions for hours trying newer and newer versions of driver, then someone suggested to start deleting drivers [actually rolling them back] by going to "Properties" and selecting uninstalling driver. I did this until I got driver version 16.5.3.6 which then got the yellow triangle with exclamation mark removed from device driver for AC 7260, rebooted and the wireless started working. Using an AC Netgear router and getting 60+ mbps on G. No dropouts.
0 Compliments
HDhal1
6 721 Visites
After reading your thread, had planned on trying ubuntu or another os in the morning to see if the cards would work. We ended up buying a 5th card from another source just to make sure the ones we had weren't dead, all code 10.
Will take a look at event viewer tab tomorrow.
For now I put the centrino n6235 cards back into the laptops. I can probably hold off another week, before having to resolve this issue, then will need to find another card to use. Bosses don't like excuses, they want it to work, and work now.
0 Compliments
BB4
6 721 Visites
Delphian, did you try the old driver?
0 Compliments
JSmyt1
6 721 Visites
Yeah i tried alot of v16 still no luck , the later versions do give more detail. i will now get the newest and try it. hopefully it will make a difference.
0 Compliments
BB4
6 721 Visites
Hmmm. Is that a Dell install of Windows? If so, what I would do is try a fresh install of Windows from a MS iso, not a Dell recovery disk, and then download drivers from the OEMs rather than Dell, for whichever ones you're not absolutely bound to Dell as the source.
When I fresh installed my Thinkpad, I used an iso and then got drivers direct from Intel for chipset, video, wireless, ethernet, bluetooth. Sound from Realtek, and only peripherals from Lenovo.
Think about it. Might be something funky from Dell that's interfering. Could be a longshot, but it's a possible variable that should be considered and/or eliminated.
0 Compliments
JG_F
Débutant
6 467 Visites
Same here.
Trying to update one MSI GT70-0nc with Intel Centrino N2230 for the Intel 7260AC with Windows 10 64 bits and I got code 10 error unable to load using every card driver from Windows 7 64 bits, Windows 8.1 64 bits and Windows 10 64 bits.
And after tried to update one Clevo W150ER with one Realtek 8723AE with the Intel 7260AC also with Windows 10 64 bits and got the same code 10 with every driver!!!!!
I don't know why intel designs some kind of hardware with that bad driver support. better not to manufacture it......
0 Compliments
ASouz7
Contributeur émérite II
6 467 Visites
jegarfor,
We understand you want to replace the current wireless adapter on your MSI* GT70-0nc for the Intel® Dual Band Wireless-AC 7260, correct?
Before we go any further, our first recommendation is to contact the http://www.intel.com/content/www/us/en/support/topics/OEMs.html Computer Manufacturer for additional support as they are the only ones entitled to provided a list of Intel® Adapters that are fully compatible with your system. In this case, code 10 may represent the following:
1. Device Manager can't start the device.
2. One of the drivers that the device needs does not start.
3. Device Manager has insufficient infromation to recognize the error that is bubbled up by the device driver.
*This may occur because the Intel® Dual Band Wireless-AC 7260 may not be fully compatible to your computer system requirements.
We also would like to take this opportunity and inform you that Intel does not support integration which is when the original wireless adapter is replaced by another one. This online advisory contains more detailed information on this matter: http://www.intel.com/content/www/us/en/support/network-and-i-o/wireless-networking/000005687.html?wapkw=regulatory+information+regarding+hardware+installation Regulatory Information Regarding Hardware Installation or Upgrade
As a second option and to help you further with this situation, you may try a clean installation of the drivers by using our generic drivers found in our download center. Here is how you can do it:
1. Download and save the lastest driver version accoring to your OSversion and architecture: https://downloadcenter.intel.com/product/75439/Intel-Dual-Band-Wireless-AC-7260 Drivers & Software
2. Go to Control Panel, Programs and Features and Uninstall "Intel® PROSet/Wireless Software", if it is installed. When prompted, choose the option to "Discard settings".
3. Also in Programs and Features, Uninstall Intel® WiDi Software.
4. In Control Panel, Device Manager, Network Adapters, right click on the Intel® Dual Band Wireless-AC 7260 and Uninstall it. Make sure you mark the option to "Delete the driver software for this device".
5. Reboot the PC or scan for hardware changes, check device manager and if an older driver is detected and installed, repeat the actions to uninstall and delete it as well. Repeat this process until the OS does not allow deleting the driver, or until the controller shows as Unknown Device.
6. Reboot or scan for hardware changes, then uninstall and delete any older driver versions as you did for the Wireless adapter.
7. Install the Intel® Wireless driver. During the first steps of PROSet/Wireless installation, make sure to customize the installation and install all the 3 driver components.
0 Compliments
JSmyt1
6 721 Visites
Nope not dell copy of windows. Installed from an ISO.
Tried with both windows 7 and 8.1 they both do the same thing. Both from ISO's , i know my dell is OLD but it should work - Must admit its a bit like a borg , its on its 3rd motherboard , 2nd screen , lost count of the hdd;s , second optical dvd drive , on its 3rd lid , keyboard is a replacement too. ( yes all done by me , been a tech for > 20 years )
I've tried the dell drivers for the 7260 - they give the same errors , i suspect they have the same bug the intel ones do
0 Compliments
BB4
6 721 Visites
Too weird. What is it about your Dell that's different from my Lenovo, that makes your card not even start while mine now goes great guns?
(After I figured out/stumbled upon the right combo of driver+settings.)
0 Compliments
Répondre
