I have Intel AC7260 and there is a problem: after every wake from sleep mode i have limited access and no connection to the Internet. I can't ping router and any device in the network... Sometimes helps to reconnect but most often I need to reboot :/ Can someone help me please?
Yep , plz respond if it solved the problem , then we can point Intel where to fix the bug.
I checked my adapter settings and UAPSD support was already disabled, yet I still have the issue that it won't connect to AP after resuming.
Hi Guys,
Can you please try a newer driver version? Here is it:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24167&lang=eng&ProdId=3714 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24167&lang=eng&ProdId=3714
Kevin M
Hey Kevin , with 17.0.5 driver i had packet drops and other problems described here right out of the box once i installed the driver and untill i turn off U-APSD i wasnt able to push it to work as intended. After i installed this updated 17.0.6 driver i dont have any problems at all, even with UAPSD enabled. Tested notebook for about 1 hr on 2 different N routers, so far so good. Speed seems to be the same , no sleep , no connection loss, no packet losses. Ill update my experience here after few days of testing.
Thanks Kevin - I installed the latest driver you posted (17.0.6.1) and forced a sleep and resume.
Happy to report that it came back online no issues!
Will post back tomorrow again on status.
lgtm too so far. I'm slightly optimistic that you finally resolved that nasty bug
Thanks Kevin for your support!
This is good news.
Is there a change log for this driver? Does anyone know if any other issues were addressed with this release?
Euphoria only lasted for a few hours. It's back to "Attempting to authenticate" again (I did have limited access connectivity issues earlier today already, too)
I agree with ItNoWorky - a changelog would be interesting to look at. Thanks to a suggestion from another thread, I found that disabling U-APSD cured my issue, and that was with the 17.0.3 driver and now the 17.0.5.8 (the last being released from Lenovo as I have a ThinkPad T520) driver as well. Throughput is good, pings fine, no mysterious disappearing of 5Ghz networks, and it reconnects after sleep 98% of the time. When it doesn't, disabling and reenabling the NIC in Device Manager restores the connection every time.
Hence I'd be leary to change now short of a compelling changelog.
Kevin,
It looks like switching between SSIDs during sleep (going from home to work or vice versa) needs a NIC refresh.
Update on my side after 3 days:
I still get issues with wakeup from sleep. Pretty sure like Mathew says - sleep, wakeup at different SSID and you have to restart.
So this latest driver does not fix the issue completely.
I have actually reproduced the problem even on the same SSID. I will double check to verify later on (I have two SSIDs at home, so it is possible it switched between them due to some random network event), and I can definitely reproduce the sleep -> switch SSIDs -> wake issue myself.
Thank you all for the feedback. We are still working to address other issues but we are happy to hear the issue after sleep has been fixed.
I will keep you updated with new driver releases.
Kevin M
If it helps, I have errors in my event log after each of these events now. All from the WLAN-AutoConfig.
WLAN Extensibility Module has stopped unexpectedly.
Module Path: C:\Windows\System32\IWMSSvc.dll
I suspect that the issue has not been fixed - at least not for an AC 3160 on Windows 8.1 (fully up-to-date) and the driver version "17.0.6.1" from "2014-07-08" (Windows device manager). I am assuming that the AC 3160 driver shares a code base with the AC 7260.
Rough pattern (just an hour ago):
* use system on 5G WiFi with SSID Location_A (at location A) - only one BSSID
* close laptop lid -> (deep) sleep ("Kernel power" event log entry)
* two hours later, system wakes up: Wake Source: S4 Doze to Hibernate
* ... and goes to sleep (Sleep Reason: Hibernate from Sleep)
... the night passes ...
* move from location A to location B with SSID Location_B - open network, three BSSID on 5G
* open laptop lid -> wakeup
* Windows is booting from hibernation
* WiFi comes up successfully (apparently)
* Windows applies Windows Defender updates
* the system enters sleep (Sleep Reason: System Idle)
* three minutes later, resume from sleep (press power key)
* Process C:\Program Files\TOSHIBA\Teco\TecoService.exe (process ID:1360) reset policy scheme from {381b4222-f694-41f0-9685-ff5bb260df2e} to {381b4222-f694-41f0-9685-ff5bb260df2e}
(yes, twice in a row and apparently real from a policy scheme to the same policy scheme)
--> WiFi dead - not associated any more
Disabling and reenabling the AC3160 device in Windows Device Manager immediately resurrects everything. (Have a PowerShell script ready that I will use next time to accomplish this)
The device is configured such that:
* prefer 5G networks
* U-APSD support off
The rest is at defaults (as far as I remember)
Bluetooth keeps working all the time (Microsoft ARC Touch Mouse Surface Edition - Bluetooth 4.0)
I am happy to provide additional input upon encountering this the next time - please provide guidance for the exact steps.
Kevin M
It doesn't appear to be fixed.
Ok , heres small update . I have much less discussed problems but few still remains .
1. Wake up under different SSID is tricky sometimes , success rate is around 7\10, if its not connects then i just need to click my network and click connect , no need to turn off - on my wlan
2. With U-APSD enabled i have speed problems with some routers , speed is capped around 8-10 mbit and 40-50 on same router with U-APSD disabled
On previous drivers my 7260 been absolutely unusable on any router with U-APSD enabled , loss of packets , speed around 0.1 -1 mbit , DNS not responding and so on.
Hey Intel guys , dont you have 7260 card to test for all mentioned issues ?? lol )
@kevin_intel I'm back to the Microsoft driver mentioned earlier.
I just experienced serious connection issues that were not fixable - neither by restarting the computer nor by disabling/enabling the device.
Hope you're really working on improving this. It's almost embarrassing...
Just for reference - I got the same problem again, this time isolated to location A (on 5G), after waking up from hibernation.
To repair the stuck state, executing some PowerShell commands (see below) was enough to get the driver out of what appears to be a stuck state.
(The Disable-Device, Enable-Device cmdlets were downloaded from http://gallery.technet.microsoft.com/Device-Management-7fad2388 TechNet Device Management PowerShell Cmdlets)
Note, BTW, that the driver itself seems to report that it is in a healthy state.
PS C:\Windows\system32> Get-Device | Where-Object -Property Name -like "Intel*Dual Band Wireless*"
Name : Intel(R) Dual Band Wireless-AC 3160
Capabilities : 0
ConfigurationFlags : 0
InstallState : InstallStateInstalled
NumaNode : 0
UINumber : 0
Characteristics : 0
Manufacturer :
HardwareIds : {PCI\VEN_8086&DEV_08B3&SUBSYS_81708086&REV_83, PCI\VEN_8086&DEV_08B3&SUBSYS_81708086,
PCI\VEN_8086&DEV_08B3&CC_028000, PCI\VEN_8086&DEV_08B3&CC_0280...}
LocationPaths : {PCIROOT(0)# PCI(1C02)# PCI(0000), ACPI(_SB_)# ACPI(PCI0)# ACPI(RP03)# ACPI(PXSX), , }
DriverVersion : 17.0.6.1
DriverProvider : Intel
DriverDescription : Intel(R) Dual Band Wireless-AC 3160
LocationInfo : PCI bus 2, device 0, function 0
InstanceId : PCI\VEN_8086&DEV_08B3&SUBSYS_81708086&REV_83\4&13C7D2&0&00E2
Service : NETwNb64
DeviceParent : PCI\VEN_8086&DEV_9C14&SUBSYS_00011179&REV_E4\3&11583659&1&E2
DeviceSiblings :
IsPresent : True
HasProblem : False
AvailableProperties : {[DEVPKEY_NAME, Intel(R) Dual Band Wireless-AC 3160 ], [DEVPKEY_Device_DeviceDesc, Intel(R) Dual
Band Wireless-AC 3160 ], [DEVPKEY_Device_HardwareIds, System.String[]],
[DEVPKEY_Device_CompatibleIds, System.String[]]...}
PS C:\Windows\system32> Get-Device | Where-Object -Property Name -like "Intel*Dual Band Wireless*" | Disable-Device
Device Disabled
PS C:\Windows\system32> Get-Device | Where-Object -Property Name -like "Intel*Dual Band Wireless*" | Enable-Device
Device Enabled
Reboot after you've uninstalled 17.0.5 and installed 17.0.6.1 (provided by Kevin.)
After I uninstalled the old driver and installed the new driver, I put the PC to sleep and resumed. Couldn't connect. I was disappointed.
After I rebooted, I've put the PC to sleep and resumed approximately 10x with no issue!
Thank you Kevin!
![](/skins/images/1FC86CD46823E418D1E2B7B4DC10231C/responsive_peak/images/icon_anonymous_message.png)
