- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
I've tried reconnecting the cables and restarting my PC, but it still doesn't work. Whenever I restart my PC, it just shows me a notification that says;
"USB DEVICE NOT RECOGNIZED. The last USB device you connected to this computer malfunctioned, and windows does not recognize it."
Every other peripheral I have works, except for the Bluetooth option.
Any help on this matter will be greatly appreciated. Thanks in advance. :)
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello KGuti2
In order to have a better understanding of your environment and this behavior, could you please provide the following information?
- Regarding the wireless card, do you refer to the "Intel® Wi-Fi 6 Gig+ Desktop Kit" (did it come with brackets, cables, and antennas?); or do you refer to an "Intel® Wi-Fi 6 AX200"?
- Did the wireless come preinstalled on the system or did you install it?
- When did it start to happen? Did it work fine before at any time? Is this a new computer? Please provide details.
- Do you remember if this issue happened after a new Windows update or Wireless/Bluetooth driver update?
- Is there any error message on Windows® Device Manager? Please provide a screenshot to see if the Bluetooth device is present in Device Manager or if there is an error.
- Is the Bluetooth icon visible in the Windows notification area at the bottom right corner?
- Have you checked the Bluetooth is enabled in the BIOS?
Also, please run the Intel® System Support Utility (Intel® SSU) and attach the report to this thread to gather more details about your system.
1- Download the Intel® SSU and save the application on your computer.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
2- Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
3- To save your scan, click Next and click Save.
4- To attach a file, you must click the “Attach” option on the bottom left-hand corner of the response box.
Andrew G.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Good day!
Thank you for getting back to me.
I already fixed the problem. I just re-plugged the WIFI card into my motherboard. I didn't know why it disconnected my Bluetooth specifically, but I did hear a faint click before it malfunctioned (like a cigarette lighter click but much fainter).
I don't know what caused it, but it's working fine again.
Thank you for taking the time to reply.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello KGuti2
Thank you for your response.
We are glad to know that you were able to fix the problem and it has been a pleasure to assist you. We will proceed to close this inquiry.
Andrew G.
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
