Wireless
8624 Discussions
Intel AX210NGW on Ubuntu 22.10 64bit 5.19.0-23-generic keeps dropping
joshfg
WiFi 6E Laptop Upgrade Card Tri Band AX210NGW 2.4Gbps 802.11ax Wireless AX210 WiFi Bluetooth 5.2 No vPro Intel AX210NGW on Ubuntu 22.10 64bit 5.19.0-23-generic keeps dropping I have to disable and reenable to reconnect to router. It happens about 10x a day, and gets worse when bt is enabled. Bt is also very flakey. Using iwlwifi-ty-a0-gf-a0-59.ucode and iwlwifi-ty-a0-gf-a0.pnvm Not sure what to do. lspci | grep Network 6b:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)
Steven_Intel
Hello joshfg,
I am sorry you are having issues with your wireless card. I will be glad to assist you.
Could you please confirm if the wireless card was pre-installed on your system or is it a recent installation?
As well, please perform the following steps:
  1. Run # modinfo iwlwifi and check the output.
  2. If there is no output, run # lsmod | grep iwlwifi to check if the driver has been loaded.
  3. To verify that, type # dmesg | grep iwlwifi​ and if the result is also empty, the driver was not initialized and there is a distribution issue.
Please let me know of the outcome.
Steven G.
joshfg
I bought the card on Amazon and installed it.
modinfo iwlwifi
filename:       /lib/modules/5.19.0-23-generic/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
license:        GPL
description:    Intel(R) Wireless WiFi driver for Linux
firmware:       iwlwifi-100-5.ucode
firmware:       iwlwifi-1000-5.ucode
firmware:       iwlwifi-135-6.ucode
firmware:       iwlwifi-105-6.ucode
firmware:       iwlwifi-2030-6.ucode
firmware:       iwlwifi-2000-6.ucode
firmware:       iwlwifi-5150-2.ucode
firmware:       iwlwifi-5000-5.ucode
firmware:       iwlwifi-6000g2b-6.ucode
firmware:       iwlwifi-6000g2a-6.ucode
firmware:       iwlwifi-6050-5.ucode
firmware:       iwlwifi-6000-6.ucode
firmware:       iwlwifi-7265D-29.ucode
firmware:       iwlwifi-7265-17.ucode
firmware:       iwlwifi-3168-29.ucode
firmware:       iwlwifi-3160-17.ucode
firmware:       iwlwifi-7260-17.ucode
firmware:       iwlwifi-8265-36.ucode
firmware:       iwlwifi-8000C-36.ucode
firmware:       iwlwifi-9260-th-b0-jf-b0-46.ucode
firmware:       iwlwifi-9000-pu-b0-jf-b0-46.ucode
firmware:       iwlwifi-BzBnj-a0-hr-b0-72.ucode
firmware:       iwlwifi-BzBnj-a0-gf4-a0-72.ucode
firmware:       iwlwifi-BzBnj-a0-gf-a0-72.ucode
firmware:       iwlwifi-BzBnj-a0-fm4-a0-72.ucode
firmware:       iwlwifi-BzBnj-a0-fm-a0-72.ucode
firmware:       iwlwifi-gl-a0-fm-a0-72.ucode
firmware:       iwlwifi-bz-a0-fm-a0-72.ucode
firmware:       iwlwifi-bz-a0-mr-a0-72.ucode
firmware:       iwlwifi-bz-a0-gf4-a0-72.ucode
firmware:       iwlwifi-bz-a0-gf-a0-72.ucode
firmware:       iwlwifi-bz-a0-hr-b0-72.ucode
firmware:       iwlwifi-SoSnj-a0-mr-a0-72.ucode
firmware:       iwlwifi-ma-a0-fm-a0-72.ucode
firmware:       iwlwifi-ma-a0-mr-a0-72.ucode
firmware:       iwlwifi-ma-a0-gf4-a0-72.ucode
firmware:       iwlwifi-ma-a0-gf-a0-72.ucode
firmware:       iwlwifi-ma-a0-hr-b0-72.ucode
firmware:       iwlwifi-SoSnj-a0-jf-b0-72.ucode
firmware:       iwlwifi-SoSnj-a0-hr-b0-72.ucode
firmware:       iwlwifi-SoSnj-a0-gf-a0-72.ucode
firmware:       iwlwifi-SoSnj-a0-gf4-a0-72.ucode
firmware:       iwlwifi-ty-a0-gf-a0-72.ucode
firmware:       iwlwifi-so-a0-gf-a0-72.ucode
firmware:       iwlwifi-so-a0-hr-b0-72.ucode
firmware:       iwlwifi-so-a0-jf-b0-72.ucode
firmware:       iwlwifi-cc-a0-72.ucode
firmware:       iwlwifi-QuQnj-b0-jf-b0-72.ucode
firmware:       iwlwifi-QuZ-a0-jf-b0-72.ucode
firmware:       iwlwifi-QuZ-a0-hr-b0-72.ucode
firmware:       iwlwifi-Qu-b0-jf-b0-72.ucode
firmware:       iwlwifi-Qu-c0-hr-b0-72.ucode
firmware:       iwlwifi-QuQnj-b0-hr-b0-72.ucode
firmware:       iwlwifi-Qu-b0-hr-b0-72.ucode
srcversion:     C43833F943133DF8BC4BDDF
alias:          pci:v00008086d00007740sv*sd*bc*sc*i*
alias:          pci:v00008086d0000A840sv*sd*bc*sc*i*
alias:          pci:v00008086d00002727sv*sd*bc*sc*i*
alias:          pci:v00008086d00007E40sv*sd*bc*sc*i*
alias:          pci:v00008086d00002729sv*sd*bc*sc*i*
alias:          pci:v00008086d00007F70sv*sd*bc*sc*i*
alias:          pci:v00008086d000054F0sv*sd*bc*sc*i*
alias:          pci:v00008086d000051F1sv*sd*bc*sc*i*
alias:          pci:v00008086d000051F0sv*sd*bc*sc*i*
alias:          pci:v00008086d00007AF0sv*sd*bc*sc*i*
alias:          pci:v00008086d00007A70sv*sd*bc*sc*i*
alias:          pci:v00008086d00002726sv*sd*bc*sc*i*
alias:          pci:v00008086d00002725sv*sd*bc*sc*i*
alias:          pci:v00008086d00002723sv*sd*bc*sc*i*
alias:          pci:v00008086d00002720sv*sd*bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd*bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd*bc*sc*i*
alias:          pci:v00008086d00004DF0sv*sd*bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd*bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd*bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd*bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd*bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd*bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd*bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd*bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd*bc*sc*i*
alias:          pci:v00008086d0000271Csv*sd*bc*sc*i*
alias:          pci:v00008086d0000271Bsv*sd*bc*sc*i*
alias:          pci:v00008086d00002526sv*sd*bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00009074bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000014bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000012bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001012bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00003E01bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00003E02bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001014bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000850bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000950bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000930bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000910bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00008130bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00009110bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000810bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00008010bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00008050bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00008110bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00009010bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000150bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000050bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd000010D0bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001010bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000130bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001130bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001110bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000110bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00004010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000000bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000930bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000950bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000850bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000910bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000810bc*sc*i*
alias:          pci:v00008086d000024F6sv*sd00000030bc*sc*i*
alias:          pci:v00008086d000024F5sv*sd00000010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000044bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000004bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009150bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008150bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009132bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008132bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009130bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008130bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd0000D030bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd0000C030bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd00009030bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd00008030bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000B0B0bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000D0B0bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000D050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000C050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000D010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000C110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000C010bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd00001030bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd00000030bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001150bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000150bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000250bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001012bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000012bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd000001F0bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001132bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000132bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001130bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000130bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd000010B0bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000010bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009E10bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009400bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009000bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd0000520Abc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005212bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005F10bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005490bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005290bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005590bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005190bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005090bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005420bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd0000502Abc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005020bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009410bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00009310bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009510bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00009200bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00009210bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009112bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009110bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd0000900Abc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009012bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009010bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005202bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005102bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005002bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005200bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd0000500Abc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005000bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00001010bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005400bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005510bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005410bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005412bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005012bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005C10bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005210bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005302bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005310bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005100bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005110bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005010bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00000000bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00002150bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00002050bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00002110bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00002010bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00008110bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00008010bc*sc*i*
alias:          pci:v00008086d00003166sv*sd00004210bc*sc*i*
alias:          pci:v00008086d00003166sv*sd00004310bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004110bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004510bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004410bc*sc*i*
alias:          pci:v00008086d00003166sv*sd00004212bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004012bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004010bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00001170bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00001070bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008570bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008470bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00008272bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00008370bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00008270bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008062bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008060bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008172bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008170bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008072bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008070bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00000370bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000472bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000470bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00000272bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00000270bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000062bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000060bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000172bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000170bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000072bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000070bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C420bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C220bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C02Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C020bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C360bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C370bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C560bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C570bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C462bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C460bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C472bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C470bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C262bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C26Abc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C260bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C272bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000CC60bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000CC70bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C270bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C760bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C770bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C162bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C062bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C160bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C06Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C060bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C170bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C072bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C070bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004420bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004220bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000402Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004020bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00005770bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00005170bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00005072bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00005070bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004360bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004370bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004560bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004570bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004A6Cbc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004A6Ebc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004A70bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000486Ebc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004870bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004462bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000446Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004460bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004472bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004470bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004262bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000426Abc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004260bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004272bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004270bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004162bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004062bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004160bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000406Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004060bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004C70bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004C60bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004170bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004072bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004070bc*sc*i*
alias:          pci:v00008086d00000892sv*sd00000462bc*sc*i*
alias:          pci:v00008086d00000893sv*sd00000262bc*sc*i*
alias:          pci:v00008086d00000892sv*sd00000062bc*sc*i*
alias:          pci:v00008086d00000894sv*sd00000822bc*sc*i*
alias:          pci:v00008086d00000894sv*sd00000422bc*sc*i*
alias:          pci:v00008086d00000895sv*sd00000222bc*sc*i*
alias:          pci:v00008086d00000894sv*sd00000022bc*sc*i*
alias:          pci:v00008086d0000088Fsv*sd0000526Abc*sc*i*
alias:          pci:v00008086d0000088Fsv*sd00005260bc*sc*i*
alias:          pci:v00008086d0000088Esv*sd00004860bc*sc*i*
alias:          pci:v00008086d0000088Esv*sd0000446Abc*sc*i*
alias:          pci:v00008086d0000088Esv*sd00004460bc*sc*i*
alias:          pci:v00008086d0000088Fsv*sd0000426Abc*sc*i*
alias:          pci:v00008086d0000088Fsv*sd00004260bc*sc*i*
alias:          pci:v00008086d0000088Esv*sd0000406Abc*sc*i*
alias:          pci:v00008086d0000088Esv*sd00004060bc*sc*i*
alias:          pci:v00008086d00000887sv*sd00004462bc*sc*i*
alias:          pci:v00008086d00000888sv*sd00004262bc*sc*i*
alias:          pci:v00008086d00000887sv*sd00004062bc*sc*i*
alias:          pci:v00008086d00000890sv*sd00004822bc*sc*i*
alias:          pci:v00008086d00000890sv*sd00004422bc*sc*i*
alias:          pci:v00008086d00000891sv*sd00004222bc*sc*i*
alias:          pci:v00008086d00000890sv*sd00004022bc*sc*i*
alias:          pci:v00008086d00000896sv*sd00005027bc*sc*i*
alias:          pci:v00008086d00000896sv*sd00005025bc*sc*i*
alias:          pci:v00008086d00000897sv*sd00005017bc*sc*i*
alias:          pci:v00008086d00000897sv*sd00005015bc*sc*i*
alias:          pci:v00008086d00000896sv*sd00005007bc*sc*i*
alias:          pci:v00008086d00000896sv*sd00005005bc*sc*i*
alias:          pci:v00008086d000008AEsv*sd00001027bc*sc*i*
alias:          pci:v00008086d000008AEsv*sd00001025bc*sc*i*
alias:          pci:v00008086d000008AFsv*sd00001017bc*sc*i*
alias:          pci:v00008086d000008AFsv*sd00001015bc*sc*i*
alias:          pci:v00008086d000008AEsv*sd00001007bc*sc*i*
alias:          pci:v00008086d000008AEsv*sd00001005bc*sc*i*
alias:          pci:v00008086d00000084sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00000084sv*sd00001216bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001326bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001226bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001306bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001206bc*sc*i*
alias:          pci:v00008086d00000084sv*sd00001315bc*sc*i*
alias:          pci:v00008086d00000084sv*sd00001215bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001325bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001225bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001305bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001205bc*sc*i*
alias:          pci:v00008086d00000886sv*sd00001317bc*sc*i*
alias:          pci:v00008086d00000886sv*sd00001315bc*sc*i*
alias:          pci:v00008086d00000885sv*sd00001327bc*sc*i*
alias:          pci:v00008086d00000885sv*sd00001325bc*sc*i*
alias:          pci:v00008086d00000885sv*sd00001307bc*sc*i*
alias:          pci:v00008086d00000885sv*sd00001305bc*sc*i*
alias:          pci:v00008086d00000089sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00000089sv*sd00001311bc*sc*i*
alias:          pci:v00008086d00000087sv*sd00001326bc*sc*i*
alias:          pci:v00008086d00000087sv*sd00001321bc*sc*i*
alias:          pci:v00008086d00000087sv*sd00001306bc*sc*i*
alias:          pci:v00008086d00000087sv*sd00001301bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005226bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005225bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005221bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005207bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005206bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005205bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005201bc*sc*i*
alias:          pci:v00008086d00000090sv*sd00005216bc*sc*i*
alias:          pci:v00008086d00000090sv*sd00005215bc*sc*i*
alias:          pci:v00008086d00000090sv*sd00005211bc*sc*i*
alias:          pci:v00008086d0000008Bsv*sd00005317bc*sc*i*
alias:          pci:v00008086d0000008Bsv*sd00005315bc*sc*i*
alias:          pci:v00008086d0000008Asv*sd00005327bc*sc*i*
alias:          pci:v00008086d0000008Asv*sd00005325bc*sc*i*
alias:          pci:v00008086d0000008Asv*sd00005307bc*sc*i*
alias:          pci:v00008086d0000008Asv*sd00005305bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001305bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001304bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00004820bc*sc*i*
alias:          pci:v00008086d00000085sv*sd0000C228bc*sc*i*
alias:          pci:v00008086d00000085sv*sd0000C220bc*sc*i*
alias:          pci:v00008086d00000082sv*sd0000C020bc*sc*i*
alias:          pci:v00008086d00000085sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00000085sv*sd00001318bc*sc*i*
alias:          pci:v00008086d00000085sv*sd00001311bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001328bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001326bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001321bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001308bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001307bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001306bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001301bc*sc*i*
alias:          pci:v00008086d00004239sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00004239sv*sd00001311bc*sc*i*
alias:          pci:v00008086d00004238sv*sd00001118bc*sc*i*
alias:          pci:v00008086d00004238sv*sd00001111bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001326bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001321bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001307bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001306bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001301bc*sc*i*
alias:          pci:v00008086d0000422Bsv*sd00001128bc*sc*i*
alias:          pci:v00008086d0000422Bsv*sd00001121bc*sc*i*
alias:          pci:v00008086d0000422Bsv*sd00001108bc*sc*i*
alias:          pci:v00008086d0000422Bsv*sd00001101bc*sc*i*
alias:          pci:v00008086d0000423Dsv*sd00001316bc*sc*i*
alias:          pci:v00008086d0000423Dsv*sd00001216bc*sc*i*
alias:          pci:v00008086d0000423Dsv*sd00001311bc*sc*i*
alias:          pci:v00008086d0000423Dsv*sd00001211bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001326bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001321bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001221bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001306bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001206bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001301bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001201bc*sc*i*
alias:          pci:v00008086d0000423Bsv*sd00001011bc*sc*i*
alias:          pci:v00008086d0000423Asv*sd00001021bc*sc*i*
alias:          pci:v00008086d0000423Asv*sd00001001bc*sc*i*
alias:          pci:v00008086d00004236sv*sd00001114bc*sc*i*
alias:          pci:v00008086d00004236sv*sd00001014bc*sc*i*
alias:          pci:v00008086d00004236sv*sd00001111bc*sc*i*
alias:          pci:v00008086d00004236sv*sd00001011bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001104bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001004bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001101bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001001bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001124bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001024bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001121bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001021bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001216bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001315bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001215bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001314bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001214bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001311bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001211bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001326bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001226bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001325bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001225bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001324bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001224bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001321bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001221bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001306bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001206bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001305bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001205bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001304bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001204bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001301bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001201bc*sc*i*
depends:        cfg80211
retpoline:      Y
intree:         Y
vermagic:       5.19.0-23-generic SMP preempt mod_unload modversions
sig_id:         PKCS#7
signer:         Build time autogenerated kernel key
sig_key:        44:C4:53:0A:71:C8:13:EA:B8:12:BC:B4:3E:81:7F:66:89:E8:35:31
sig_hashalgo:   sha512
signature:      03:3D:91:FC:99:FC:13:3E:7D:87:F9:56:9D:00:16:8F:A4:80:10:03:
9B:44:C3:D7:0E:F7:04:24:54:FF:00:90:4A:28:D4:58:06:BC:59:2F:
A4:3B:26:94:85:4E:64:82:0C:6C:D4:23:83:40:0D:20:AB:B8:52:49:
6D:F9:51:CD:88:38:CF:13:ED:4A:5E:F0:54:C1:6C:05:65:30:0D:DA:
16:E7:B0:B4:99:AD:6D:4E:C6:76:49:DA:5F:14:C5:CE:BE:15:93:D6:
9D:6C:2A:FB:F8:42:8E:FA:1D:4A:F8:4B:2E:A7:F4:C9:35:77:0A:DE:
81:3E:86:BD:5E:E3:EB:1B:44:C8:D2:2C:0E:B7:EA:49:D3:B0:C5:45:
14:5D:55:28:52:18:35:36:1F:92:2F:78:25:D9:FC:B2:C9:5B:82:0C:
55:C0:BC:33:FB:C4:DB:5E:6F:88:0E:F9:63:12:6D:33:2B:72:CE:F6:
39:76:0E:A0:34:65:51:1B:05:07:CB:E6:F1:08:66:50:4D:09:2B:20:
D7:35:09:D1:CE:94:9D:85:4B:0D:58:BE:38:47:F0:14:2C:43:5D:72:
B9:21:FB:C2:F4:60:4A:5E:F3:DF:C8:94:34:51:DE:FC:02:EB:21:F9:
0A:2E:57:18:76:9A:36:D1:53:47:A9:79:E1:AB:8E:28:B8:CF:9E:D3:
EA:B1:DE:E6:6B:6F:C4:01:30:65:18:B3:75:94:34:4F:12:5B:01:29:
92:87:4B:30:C7:A9:BB:08:78:EB:3A:30:82:B5:C5:C1:7E:5D:56:FD:
84:D7:BB:4D:06:23:7C:D6:69:1A:06:41:87:B0:2D:7C:25:FA:46:28:
96:C0:4D:AC:41:4D:24:75:2F:8D:AE:22:3C:9A:40:FC:F1:4C:41:67:
B6:FE:4A:52:F5:25:C3:63:47:2D:1C:2A:6E:5D:4D:00:0D:1C:DA:2D:
FE:ED:AD:D4:98:BC:4C:EF:F7:C7:93:8C:A7:63:11:EE:C2:66:CA:9D:
29:BE:62:90:2D:CA:DF:B3:EB:9B:3F:BE:AC:7B:4C:2F:8C:AA:00:15:
87:54:3A:6A:18:A8:78:2E:08:DC:A7:3C:92:B1:A3:87:4C:FA:58:8F:
C3:AC:BE:D7:3D:C7:8C:F1:C9:38:BF:A5:EC:81:7B:B6:AC:8D:9B:78:
43:FF:17:A2:A9:3D:07:08:28:AA:8F:5B:D3:4C:26:54:3C:3E:5B:0B:
50:4F:CA:0B:6F:58:1B:1A:FB:2B:FB:58:28:C8:31:2D:B6:72:64:CB:
16:77:CE:00:8D:DF:F4:64:9D:4D:D4:0B:40:11:8D:C3:0A:5D:01:D7:
DD:47:6C:2A:0E:53:94:20:B9:F2:3E:D1
parm:           swcrypto:using crypto in software (default 0 [hardware]) (int)
parm:           11n_disable:disable 11n functionality, bitmap: 1: full, 2: disable agg TX, 4: disable agg RX, 8 enable agg TX (uint)
parm:           amsdu_size:amsdu size 0: 12K for multi Rx queue devices, 2K for AX210 devices, 4K for other devices 1:4K 2:8K 3:12K (16K buffers) 4: 2K (default 0) (int)
parm:           fw_restart:restart firmware in case of error (default true) (bool)
parm:           nvm_file:NVM file name (charp)
parm:           uapsd_disable:disable U-APSD functionality bitmap 1: BSS 2: P2P Client (default: 3) (uint)
parm:           enable_ini:0:disable, 1-15:FW_DBG_PRESET Values, 16:enabled without preset value defined,Debug INI TLV FW debug infrastructure (default: 16)
parm:           bt_coex_active:enable wifi/bt co-exist (default: enable) (bool)
parm:           led_mode:0=system default, 1=On(RF On)/Off(RF Off), 2=blinking, 3=Off (default: 0) (int)
parm:           power_save:enable WiFi power management (default: disable) (bool)
parm:           power_level:default power save level (range from 1 - 5, default: 1) (int)
parm:           disable_11ac:Disable VHT capabilities (default: false) (bool)
parm:           remove_when_gone:Remove dev from PCIe bus if it is deemed inaccessible (default: false) (bool)
parm:           disable_11ax:Disable HE capabilities (default: false) (bool)
iwlwifi               503808  1 iwlmvm
cfg80211             1040384  3 iwlmvm,iwlwifi,mac80211
sudo dmesg | grep iwlwifi
[    3.136114] iwlwifi 0000:6b:00.0: Direct firmware load for iwlwifi-cc-a0-72.ucode failed with error -2
[    3.137628] iwlwifi 0000:6b:00.0: api flags index 2 larger than supported by driver
[    3.137660] iwlwifi 0000:6b:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.37
[    3.138414] iwlwifi 0000:6b:00.0: loaded firmware version 71.058653f6.0 cc-a0-71.ucode op_mode iwlmvm
[    3.576180] iwlwifi 0000:6b:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[    3.730668] iwlwifi 0000:6b:00.0: Detected RF HR B3, rfid=0x10a100
[    3.801203] iwlwifi 0000:6b:00.0: base HW address: c0:3c:59:ee:83:6f
[    3.819548] iwlwifi 0000:6b:00.0 wlp107s0: renamed from wlan0
[12558.124618] iwlwifi 0000:6b:00.0: Unhandled alg: 0x707
Steven_Intel
Thank you for your response.
Since you have installed the wireless adapter, please be aware of the Regulatory Information Regarding Wireless Hardware Installation or Upgrade (https://www.intel.com/content/www/us/en/support/articles/000005687/wireless.html)
I am going to work on this issue. As soon as I have an update, I will let you know.
Steven G.
Steven_Intel
Hello joshfg,
Please try the latest stable kernel 6 and let me know if the issue persists.
Steven G.
Steven_Intel
Steven G.
Steven_Intel
Since we have not heard back from you, we will close this thread. If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Steven G.
