I have sent you a Private Message (PM). Check your PM Inbox. Click on your avatar picture in the top right corner of the page (in the Communities blue banner) and select Messages from the resulting menu.
P.S. You are the 153rd requestor since Jan. 6th.
Hi, Scott. I’m Nant from Thailand
I have some problem about wifi driver because of my old version of laptop.
I’ve been suggested from my friend from computer society that you have a driver of AC-3160 for window10
Could you please share it to me?
Thank you
Same as many others, I would like to get access to the AC-3160 driver you have shared.
Thank you!
P.S. You are the 155th requestor since Jan. 6th.
Thank you
Thank you
Thank you n_scott_pearson for your service to the community.
I also find myself needing the Windows 10 drivers for the Wireless-AC 3160, I hope you can help me out.
Intel, if you are listening, it is absurd to remove the download for this driver that people OBVIOUSLY need, as shown by this thread.
EDIT: I wound up installing a spare PCI WiFi card I happened to have around to avoid the entire issue. Not real happy about the end of support for this, but I'd rather use hardware that has active support.
Thanks!
Please share with me as well. 18.33.13.4 and newer, per trying to resolve this issue, https://www.intel.com/content/www/us/en/support/articles/000054799/wireless.html
P.S. You are the 160th requestor since Jan. 6th.
I will be the millonth! If you could send me the file to update my driver I will so appreciate it, my work laptop cannot connect to the new router and I'm desperate.
Thank you very much in advance,
Gabie
P.S. You are the 164th WLAN driver requestor since Jan. 6th.
Hi Scott (@n_scott_pearson),
would you be so kind to help me out with the same problem. I have missed to update the wlan driver for AC 3160.
Is it still possible for you?
Thank you and kind regards,
Alla
P.S. You are the 176th requestor since Jan. 6th.
@n_scott_pearson I would be forever grateful if you could send this to me as well! I have been scouring the interwebs looking for this solution, which is my final attempt at getting my wifi connected to this PC.
Thank you!!!
Just for completeness:
P.S. You are the 179th requestor since Jan. 6th.
Hello Scott, Can you share the driver link to me please? I have sent a PM to you.
Bala
P.S. You are the 183rd and 184th WLAN driver requestors since Jan. 6th.
P.S. You are the 190th WLAN driver requestor since Jan. 6th.
I have sent you a Private Messages (PM) with a link to my share providing these driver packages. Check your Private Message inbox. Click on your avatar picture in the top right corner of the page (in the Communities blue banner) and select Messages from the resulting menu.
P.S. You are the 209th WLAN Driver requestor since Jan. 6th.
Everything went well.
Thank you very much!
Yuki.
