Wireless
7813 Discussions
Intel Dual Band Wireless AC-3160 drivers
nice1488
I bought a LG 24V360 computer a while ago and a few days ago I formatted it for some problems, I installed the drivers but I can't find anything about Intel Dual Band Wireless AC-3160 drivers for Windows 10 and I found that it is discontinued, what can I do?
Dabs
Unfortunately, BT file didn't work for my Dell laptop it just booted my mouse off.
At the moment laptop connected through wifi extender but HP printer still won't print unless connected to laptop, no printing from mobile devices.
n_scott_pearson
Per the release notes, 21.10.1 is the last package with support for the 7260 and 3160. The actual driver included in this package is 18.33.17.1, which it looks like you had already from your Windows 10 to Windows 11 upgrade. I would add that this driver is listed as supporting Windows 10; there is no indication of Windows 11 support. This doesn't necessarily mean that it won't work, but it also doesn't mean that it will (i.e. there was no validation so there is no guarantee). Such is what happens when discontinuation dates occur too close to O/S release dates.
I hope that you were asking for the update just to ensure that you have the latest (last) release and that it was actually working for you. If not, let us know what is going wrong and we will endeavor to sort out whether there is anything we can do about it.
energyx
18.33.17.1 was installed by Windows 11 from Windows Update Optional Updates, so it would appear to still be available for download through that method. Thanks for posting.
n_scott_pearson
@Roadie_SG@Art9245,
Check your Private Message inbox. Click on your avatar picture in the top right corner of the page (in the Communities blue banner) and then select Messages from the resulting menu.
P.S. You are the 129th and 130th requesters since Jan. 6th.
inuz
I have a AC-3160 device. But I do not have AC-3160 drivers for windows10.
Therefore I can not connect WiFi6 Access Point. Please share driver package.
Thank you a lot.
n_scott_pearson
@inuz,
I have sent you a Private Message (PM) with a link to my share providing these driver packages. Check your Private Message Inbox. Click on your avatar picture in the top right corner of the page (in the Communities blue banner) and select Messages from the resulting menu.
P.S. You are the 144th requestor since Jan. 6th.
inuz
@n_scott_pearson
Thanks for the helpful advice!
I can connect to WiFi6 AP with AC-3160.
n_scott_pearson
@Wenceslau,
I have sent you a Private Message (PM). Check your PM Inbox. Click on your avatar picture in the top right corner of the page (in the Communities blue banner) and select Messages from the resulting menu.
P.S. You are the 151st requestor since Jan. 6th.
EnisKirazoglu
@n_scott_pearson
Hello, is it still possible to share these driver packages with me?
n_scott_pearson
@EnisKirazoglu,
P.S. You are the 153rd requestor since Jan. 6th.
NefertitiNant
Hi, Scott. I’m Nant from Thailand
I have some problem about wifi driver because of my old version of laptop.
I’ve been suggested from my friend from computer society that you have a driver of AC-3160 for window10
Could you please share it to me?
Thank you
PurpleBeast
Same as many others, I would like to get access to the AC-3160 driver you have shared.
Thank you!
n_scott_pearson
@PurpleBeast,
P.S. You are the 155th requestor since Jan. 6th.
Kya9576
Hello, please may you share the same driver with me also AC-3160 for windows 10/11
Thank you
Thank you
ecosky
Thank you n_scott_pearson for your service to the community.
I also find myself needing the Windows 10 drivers for the Wireless-AC 3160, I hope you can help me out.
Intel, if you are listening, it is absurd to remove the download for this driver that people OBVIOUSLY need, as shown by this thread.
EDIT: I wound up installing a spare PCI WiFi card I happened to have around to avoid the entire issue. Not real happy about the end of support for this, but I'd rather use hardware that has active support.
Thanks!
aiwa
Please share with me as well.  18.33.13.4 and newer, per trying to resolve this issue, https://www.intel.com/content/www/us/en/support/articles/000054799/wireless.html
n_scott_pearson
@aiwa,
P.S. You are the 160th requestor since Jan. 6th.
Vorahut
Gabie
I will be the millonth! If you could send me the file to update my driver I will so appreciate it, my work laptop cannot connect to the new router and I'm desperate.
Thank you very much in advance,
Gabie
n_scott_pearson
@Vorahut,
P.S. You are the 164th WLAN driver requestor since Jan. 6th.
Alla_TAB
Hi Scott (@n_scott_pearson),
would you be so kind to help me out with the same problem. I have missed to update the wlan driver for AC 3160.
Is it still possible for you?
Thank you and kind regards,
Alla
