Is it possible for me to get the drivers also please
I have sent you a download link via the Communities Private Message (PM) service. For this message, check your PM inbox. Click on your avatar picture in the top right corner of the page (in the blue Communities banner) and then select Messages from the resulting menu.
P.S. You are the 335th WLAN Driver requestor since Jan. 6th.
The same problem here. I'd appreciate the download link too
@nescha,
P.S. You are the 334th WLAN Driver requestor since Jan. 6th.
P.S. You are the 337th WLAN Driver requestor since Jan. 6th.
@n_scott_pearson Hi Scott, can you please send me the link to the latest AC 3160 driver also? I was trying to set up a Deco AXE5300 Mesh Network and for some reason my AC3160 wifi card was not able to find the SSID. After a few hours of extensive research, the old driver on AC3160 may be culprit. Thanks in advance!
P.S. You are the 338th WLAN Driver requestor since Jan. 6th.
Hi Scott, thank you for the link to the driver. I was able to download/install the driver and looks like the latest driver fixed my problem finding the SSID on my Deco mesh network. Thank you!
Hi scot you had sent me the link but i had went on vacation and it dissapeared could you please resend? If not I understand. Thanks for any consideration.
My lennovo keeps dropping wifi, I can be connected and my laptop just randomly drops connection and then says cant connect to this network, is this a problem the new drivers could ffix?
Hi @n_scott_pearson , I need the drivers as well. Could you please send them to me? Thanks in advance!
P.S. You are the 341st WLAN Driver requestor since Jan. 6th.
P.S. You are the 345th WLAN Driver requestor since Jan. 6th.
Hello there i would need these drivers as well. Could you please send them to me?
@Grangelz and @Jellybelly,
I have sent you both a download link via the Communities Private Message (PM) service. For your message, check your PM inbox. Click on your avatar picture in the top right corner of the page (in the blue Communities banner) and then select Messages from the resulting menu.
P.S. You are the 346th and 347th WLAN Driver requestors since Jan. 6th.
I resent the link.
Hi, I'd appreciate the download link too for wireless and bluetooth, Thank you!
P.S. You are the 356th WLAN Driver requestor since Jan. 6th.
Hi Scott,
Looks like you are a savior to many of us. I am having the same issue. Upgraded my Router and my laptop wireless driver is too old to see the new wireless network. I also need the Intel Dual Band Wireless AC-3160 drivers.
Would you be able to send me the link?
Thanks in advance.
![](/skins/images/C4F7392A5C68ACA60290C9576F107044/responsive_peak/images/icon_anonymous_message.png)
