Wireless
8607 Discussions
Intel Dual Band Wireless AC-3160 drivers
nice1488
I bought a LG 24V360 computer a while ago and a few days ago I formatted it for some problems, I installed the drivers but I can't find anything about Intel Dual Band Wireless AC-3160 drivers for Windows 10 and I found that it is discontinued, what can I do?
JKarki
Hello! I am facing same problem. Would you mind sending me the drivers? Thanks a lot in advance!
Luis_Yock16
Hello Scott,
I'm having same issue with my laptop that have an Intel(R) Dual Band AC-3160, could you please share with me the latest driver that was available?, to see if I'm avaible to fix my issue.
Best Regards.
SAB0
Please send the drivers to me as well im practically jobless without my driver working
Gabie
Hi SAB0,
Check in the last page of this thread a post by  n_scott_pearson dated 08-03-2023 with a link to the driver.
Carlos_ZC
Hi Scott,
Reciently I changed the router and my child's laptop don't recognize the wifi signal. I was wondering if I could get the latest update for the AC-3160 as well.  I would very much appreciate it.
Thank you in advance !
Greetings from Spain
Carlos
n_scott_pearson
Yes, a very common problem when a WiFi6 router is encountered. Intel, in the last driver release for these older WiFi cards, enhanced the code to communicate reliably with these newer routers.
Since Intel is no longer providing the drivers for these older, discontinued WiFi cards and since I had these drivers in my archive, I set up a share to provide them to the masses. Here is a link that will allow you to pull the files: https://1drv.ms/f/s!AtacZBU04mo-j-tQ34BdSDv6y1BFsg?e=7gn50T. Once you open the share, choose the subfolder that supports your adapter.
Hope this helps,
Mike-Man
Thank you very much for the codes I downloaded them and my computer picks up my network just fine now. Much appreciated.
Mike-man
Siy
Hi Scott
I am having the same issue. Would you mind sending me the driver also?
Thanks in advance.
AndreiSorin
n_scott_pearson
@AndreiSorin,
You can find the appropriate driver installation files in my legacy driver share: https://1drv.ms/f/s!AtacZBU04mo-j-tQ34BdSDv6y1BFsg?e=7gn50T.
Nilton_Rocha
You are an angel, my friend. Please help me, I am facing the same issue with the driver for the Intel 3160HMW.
Bobbalybob
Hello
I am new on this forum. I just saw that you have the latest version for the Ac 3160.
I would also be very greatfull if you could send it to me.
Many thanks in advance!
BMET
Hi Scott, I too need some help with getting the latest driver for the Intel Daul Band Wireless AC 1360 adapter.
Can you please send me what you have I greatly appreciate the help. Currently, I am using a driver from 2015.
Wireless AP's were updated and I lost wireless network conductivity.
Thanks, Ron
BMET
David68
Hello Scott..I have the same situation with the Intel Dual Band Wireless AC-3160 driver. May I also have the driver? Many thanks in advance!
StevenSMurphyPE
Scott,
I purchased a new dual band Wi-Fi 6 router and need the Wireless AC-3160 driver for Windows 10 that supports Wi-Fi 6.  Much Appreciated.
Steven
n_scott_pearson
@StevenSMurphyPE,
Use this link: https://1drv.ms/f/s!AtacZBU04mo-j-tQ34BdSDv6y1BFsg?e=7gn50T to access my archive. Subfolders provide final driver packages for most of the Discontinued Wireless adapters.
Hope this helps,
Swam
Hello, I have same issue too. Please kindly help me to find that drivers. I try nearly 3 hours finally found this post. Plz help me.T_T
SaintGilliam
Hello Scott, I know this an old post but I need those driver updates as well. I cannot connect to new networks when the router is new. So I would be much obliged if you could send me those! Thank you
n_scott_pearson
Hope this helps,
Mohitalan
Can i also have the driver please
I killed my laptops wifi card accidentally and have this card in spare
Unfortunate for me they discontinued this product:(
Help would be appreciated
