Hi SAB0,
Check in the last page of this thread a post by n_scott_pearson dated 08-03-2023 with a link to the driver.
Hi Scott,
Reciently I changed the router and my child's laptop don't recognize the wifi signal. I was wondering if I could get the latest update for the AC-3160 as well. I would very much appreciate it.
Thank you in advance !
Greetings from Spain
Carlos
Since Intel is no longer providing the drivers for these older, discontinued WiFi cards and since I had these drivers in my archive, I set up a share to provide them to the masses. Here is a link that will allow you to pull the files: https://1drv.ms/f/s!AtacZBU04mo-j-tQ34BdSDv6y1BFsg?e=7gn50T. Once you open the share, choose the subfolder that supports your adapter.
Hope this helps,
Thank you very much for the codes I downloaded them and my computer picks up my network just fine now. Much appreciated.
Mike-man
Hi Scott
I am having the same issue. Would you mind sending me the driver also?
Thanks in advance.
You can find the appropriate driver installation files in my legacy driver share: https://1drv.ms/f/s!AtacZBU04mo-j-tQ34BdSDv6y1BFsg?e=7gn50T.
You are an angel, my friend. Please help me, I am facing the same issue with the driver for the Intel 3160HMW.
Hello
I am new on this forum. I just saw that you have the latest version for the Ac 3160.
I would also be very greatfull if you could send it to me.
Many thanks in advance!
Hi Scott, I too need some help with getting the latest driver for the Intel Daul Band Wireless AC 1360 adapter.
Can you please send me what you have I greatly appreciate the help. Currently, I am using a driver from 2015.
Wireless AP's were updated and I lost wireless network conductivity.
Thanks, Ron
Hello Scott..I have the same situation with the Intel Dual Band Wireless AC-3160 driver. May I also have the driver? Many thanks in advance!
Scott,
I purchased a new dual band Wi-Fi 6 router and need the Wireless AC-3160 driver for Windows 10 that supports Wi-Fi 6. Much Appreciated.
Steven
Use this link: https://1drv.ms/f/s!AtacZBU04mo-j-tQ34BdSDv6y1BFsg?e=7gn50T to access my archive. Subfolders provide final driver packages for most of the Discontinued Wireless adapters.
Hope this helps,
Hello Scott, I know this an old post but I need those driver updates as well. I cannot connect to new networks when the router is new. So I would be much obliged if you could send me those! Thank you
Hope this helps,
I killed my laptops wifi card accidentally and have this card in spare
Unfortunate for me they discontinued this product:(
Help would be appreciated
Hope this helps,
Hello scott, can you also send me the the driver files. I really need it thanks in advance
Hope this helps,
![](/skins/images/3344F5B3B76C91485ED0E980FD0CA95E/responsive_peak/images/icon_anonymous_message.png)
