Wireless
7896 Discussions
Intel Dual Band Wireless AC-3160 drivers
nice1488
I bought a LG 24V360 computer a while ago and a few days ago I formatted it for some problems, I installed the drivers but I can't find anything about Intel Dual Band Wireless AC-3160 drivers for Windows 10 and I found that it is discontinued, what can I do?
n_scott_pearson
@Tytris,
I have sent you a download link via the Communities Private Message (PM) service. For this message, check your PM inbox. Click on your avatar picture in the top right corner of the page (in the blue Communities banner) and then select Messages from the resulting menu.
P.S. You are the 371st WLAN Driver requestor since Jan. 6th.
n_scott_pearson
Yea, best you are going to be able to do with this card is a WiFi 5 connection. Still, if this is working at a reasonable rate, you should be all set to putter along until you decide the whole thing needs to be upgraded.
Mike-Ireland
I am pleased that I can still use this old laptop now so delighted with WiFi 5.
I suspect that it would be difficult to get a card that would be compatible with my old Dell Inspiron 15 5000 series ( the one with the hard drive and no internal SSD).
However really happy to take your advice if you can recommend a newer card.
Thank you again for providing access to the driver. You have saved me from buying a new laptop that I  do not really need!
Mike
n_scott_pearson
@Mike-Ireland - my advice is detailed above (see 7/27/23 post). Physically, unless Dell permanently soldered the silicon to their motherboard, you should be able to install a replacement card. The big question is whether Dell pulled a slimy move and blocked upgrades using an Inclusion/Exclusion list in their BIOS. This I can't answer - and Dell support likely will play dumb.
Mike-Ireland
Thank you. I will try over the next couple of months and come back to the forum to report.
n_scott_pearson
@LIGREENIZS,
P.S. You are the 374th WLAN Driver requestor since Jan. 6th.
n_scott_pearson
I have been doling out the drivers to one user at a time, so that I could collect user information to use in my argument that the files need to be reposted. I am at the point of giving up, however. Intel is saying that there is a security risk associated with reposting the drivers and that Intel Legal is simply not going to allow it.
So, I am providing a share link here that will allow anyone to pull the final file releases for the various discontinued Wireless Adapters that I had archived: https://1drv.ms/f/s!AtacZBU04mo-j-tQ34BdSDv6y1BFsg?e=7gn50T. Where possible, I have included the original Release Note files; where not possible, I have created Release Note files with what information I have access to.
If someone wants to take these files and put them on a file sharing service, go for it. Let me know where they are available and I will remove them from my share.
Wireless_work
Thank-you so much Scott! You're the best
n_scott_pearson
Look at my ‎08-03-2023 post.
n_scott_pearson
@MusicMasters,
n_scott_pearson
@JKarki,
William10
Hi Scott
Kindly send me the driver link in DM?
n_scott_pearson
@Luis_Yock16@William10,
Look at my ‎08-03-2023 post in this same conversation.
n_scott_pearson
@Gabie,
n_scott_pearson
@BoKun,
You can find the approrpiate driver installation files in my legacy driver share: https://1drv.ms/f/s!AtacZBU04mo-j-tQ34BdSDv6y1BFsg?e=7gn50T.
BoKun
n_scott_pearson
@Siy,
You can find the appropriate driver installation files in my legacy driver share: https://1drv.ms/f/s!AtacZBU04mo-j-tQ34BdSDv6y1BFsg?e=7gn50T.
Seenoon
I need that driver bro
Seenoon
Hi Scott! Would you mind sharing also the latest drivers for Intel-Dual-Band-Wireless-AC-3160. Thanks you so much bro
n_scott_pearson
@Seenoon,
Use this link: https://1drv.ms/f/s!AtacZBU04mo-j-tQ34BdSDv6y1BFsg?e=7gn50T to access my archive. Subfolders provide final driver packages for most of the Discontinued Wireless adapters.
Hope this helps,
n_scott_pearson
OMG, Again! People: turn off threaded display!
@Nilton_Rocha,
Hope this helps,
