Use this link: https://1drv.ms/f/s!AtacZBU04mo-j-tQ34BdSDv6y1BFsg?e=7gn50T to access my archive. Subfolders provide final driver packages for most of the Discontinued Wireless adapters.
Hope this helps,
Hello scott, can you also send me the the driver files. I really need it thanks in advance
Hope this helps,
Hello Sir,
I also have similar issue with the windows 10. I use DECO router but the WIFI cannot be detected for the network adapter AC3160.
The version i got from Intel is 18.20.0.9 version which I understand does not support DECO for the AC 3160 . Can you please help here ?
The details for my systems are as below:
Windows: Windows 10 (22H2 ) 64 bit
Laptop : Dell Inspiron 7547
Network Adapter: Intel® Dual Band Wireless-AC 3160 (18.20.0.9)
I checked the DECO requirements , it requires (18.33.13.4 and above) versions to be compatible .
https://www.tp-link.com/my/support/faq/2303/
Please guide me accordingly. Appreciate your help.
Thanks & Regards,
Appu
Hi Scott just gone through the thread . May i also have a copy of this driver? Just gone through an complete reset of my device and this has been bugging me in the last 5-8 hrs . Thanks!
Can I get a copy of the driver as well? I would really appreciate it.
I just scrolled briefly in this thread and copied this for you:
[If you find any Intel driver you might need, download and save it now.]
Hi I wonder if i could have a copy of the driver please.
and followed lots of other advice to no effect, reset his hub / router but no change. He has an AC 3160 card and I would be so grateful for the latest drivers available; can you assist please?
Do you still have the drivers for the WiFi Wireless Card 3160NGW? If so can you please send me them in my inbox? It would be greatly appreciated!
- Tags:
- hero
I also require the AC 3160 drivers please.
Thank you,
Iwan Goussard
Hope this helps,
Scott, I know it's the end of 2024 but I'm hoping you still have these drivers?
I had to disable the wifi and bluetooth from the bios fault of wright driver.
Can you please send it to me also?
I have sent you a Private Message (PM) with a link to my share providing these driver packages.
P.S. You are 45th user that I have provided these drivers to since Jan. 6th.
would it be possible, that you send me a link for this, too?
It really sucks, that intel does not host an archive of old drivers. Don't know what the problem is?!
Thank you
Wolfgang
