Wireless
8506 Discussions
Intel Dual Band Wireless-AC 7260 isn't working
HCons
Hi guys.
My wireless device is not working properly.
Sometimes I can connect on wi-fi and minutes later, the device stop working and I can't see any wi-fi network on range.
I'm sending the report generated with cmd command: wlan-report-latest.html (.rar).
I appreciate if you could help me to solve this issue.
Thank you in advance.
Best regards.
xackley
It appears I fixed mine. HP zbook G2 Win10 with a 7260. Sometimes my wifi was resetting a quite a few times an hour.
I installed drivers from 2015. Now I have good performance with no disconnects.
17.13.11.5
Look into drivers for Win 7 or 8. Run their install. The install will not update the active driver, but it makes it available for you to select Browse your Local computer. Then you pick a driver already on your PC.
Microsoft doesn't make it easy to install an old driver, and you need to turn off auto Driver Updates
Don
HCons
@xackley​  Thanks for your message.
I found this driver on Support Site: WiFi_20.120.0_Driver64_Win10
I think this is the updated version to Win10. :)
I've installed this file and, apparently, the wi-fi device is working correctly.
Best regards.
@HCons​
