I have sent you a download link via the Communities Private Message (PM) service. For this message, check your PM inbox. Click on your avatar picture in the top right corner of the page (in the blue Communities banner) and then select Messages from the resulting menu.
P.S. You are the 322nd WLAN Driver requestor since Jan. 6th.
P.S. You are the 349th WLAN Driver requestor since Jan. 6th.
Hi Scott, I am also having problems with my AC 7260 dis-connecting. I am running the latest WIN10 in Lenovo Thinkpad Yoga 14. Can you share the drivers. Thanks!
P.S. You are the 350th WLAN Driver requestor since Jan. 6th.
I am also having problems with my AC 7260 unable to see SSID's. Can i also have the latest firmware
P.S. You are the 352nd WLAN Driver requestor since Jan. 6th.
hello, n_scott_pearson could you please send me the link that contains the latest version of the Dual Wireless AC 7260 windows 10 &11 driver
P.S. You are the 357th WLAN Driver requestor since Jan. 6th.
I have been doling out the drivers to one user at a time, so that I could collect user information to use in my argument that the files need to be reposted. I am at the point of giving up, however. Intel is saying that there is a security risk associated with reposting the drivers and that Intel Legal is simply not going to allow it.
So, I am providing a share link here that will allow anyone to pull the final file releases for the various discontinued Wireless Adapters that I had archived: https://1drv.ms/f/s!AtacZBU04mo-j-tQ34BdSDv6y1BFsg?e=7gn50T. Where possible, I have included the original Release Note files; where not possible, I have created Release Note files with what information I have access to.
If someone wants to take these files and put them on a file sharing service, go for it. Let me know where they are available and I will remove them from my share.
Best regards.
Thanks. My ThinkPad T410s with Windows 7 is really old, but its swichable number keypad, 16:10 ratio screen, reliability and easy of understanding, make it a nice tool for my work mainly based on Excel,just like a bicycle to and from work.
Here I attach a System Log under normal startup since the previous logs has been cleared and startup stuck hasn't occured during the past several days. Please start from 2023/9/4. The differace is, under starup stuck, there will be more than a dozen NETwNs64 items, the details of which are the same as the second and third ones of 3023/9/4 in this log, all related to \Device\NDMP4(or NDMP5,6,etc).
Please understand my English expression. I come from mainland China.Thanks again.
BTW,I'm wonder why I cannot reply the post on my laptop with Microsoft Edge? Now I have to do that on my iPhone's Safari.
Dear Scott, it just happened during a hot reboot. I save and attach the system log here. Please start attach at 2023/9/5 16:59:55.
Thanks again.
Do you have both the Intel Chipset Device Software and Intel Management Engine packages installed? I am seeing a HECI event (Not-Found condition, I think) at the same time.
Yes, I’m sure I have the both installed.
And I’ve noticed that the event-ID of NETwNs64 are 7001 or 7036 etc under normal startup while 5002 or 5005 under stuck. But Windows said that it couldn’t find the description of event-ID 50xx or 70xx. Could you consider these differences?
Thanks again. And hope this issue doesn’t bother you as much as what the community forum did for me: I just posted a new thread since I can’t reply on this thread, then I find can reply using a VPN.
Maybe I’ve resolved my two issues: I downloaded a 7260 driver (Rev. 16.10.0.5) from Microsoft Update Catalog, which worked well and stable on my laptop with Windows 7. And I can reply if I get access to this website through a VPN.
Thanks again.
And Rev. 17.16.0.4 downloaded from Toshiba website seems working well too.
Hello Scott.
As another users I also having problems with my AC 7260 disconnecting. I am running the latest WIN10 in Asus X751L. I need to use the wireless conecttion an also de Bluetooth.
Please send me the lastest wireless and bluetooth AC 7260 driver for Windows 10 and 11 64 bit.
Thank you in advance
I have been doling out the drivers to one user at a time, so that I could collect user information to use in my argument that the files need to be reposted. I am at past the point of giving up, however. Intel is saying that there is a security risk associated with reposting the drivers and that Intel Legal is simply not going to allow it.
Use this link: https://1drv.ms/f/s!AtacZBU04mo-j-tQ34BdSDv6y1BFsg?e=7gn50T to access my archive. Subfolders provide final driver packages for most of the Discontinued Wireless adapters.
Hope this helps,
![](/skins/images/7FC17B7B85029576C25F1E43CE255B51/responsive_peak/images/icon_anonymous_message.png)
