Hi all and Intel community, I've updated to Windows 11 quite a few months ago.
Three days ago after some updates I was surprised to see I could not to connect to any WiFi network anymore. I saw in the device manager (Window + X ) that my network card was having an issue. I share the screen with this post. I tried many things (I roll back to a previous windows with rstrui on terminal prompt : it worked for a few minutes but then crashed, I also tried to deactivate the network card or to reupdate the driver but nothing changed). I'm thinking of a full system reset...
With this post I also provide the SSU report and the Intel Killer report since it has start to not function anymore. Tell me if you need it in french.
Hi, Makar.
Thank you for posting in our Community.
You seem to be dealing with a challenging WiFi connectivity problem following an update to Windows 11. Upon reviewing the SSU report and the screenshot you've shared, it's evident that the Killer(R) Wi-Fi 6 AX1650x is marked with a yellow bang. Could you please check the device status and relay the specific error message it displays (for example: Code 10, 22, 28, 31, 43, or 45)? This will help in diagnosing the problem further.
Looking forward to your response. Have a nice day!
Von M.
Hi and thanks for your answer Sir, the device status says : Windows is still setting the class configuration for this device (Code 56).
Hi, Makar.
Thank you for getting back to us. In addition, this error message often occurs due to a conflict between a network adapter installed on the system and third-party VPN (Virtual Private Network) software. You can attempt the following steps that might help fix the issues, checking after each one to see if the issue is resolved:
Hi @Makar i'm having the same issue, but my error code is 10, i have tried to uninstall the drivers and add the most updated driver from intel and didn't work. Thank you in advance.
Hi, Makar.
I trust you're doing well.
I have not heard back from you, we will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Von M.
I have the same issue but error 43. I updated the drives and even windows. But wifi is still not functional. Please give me a detailed solution to this matter.
What I noticed is that, whenever I update killer wifi suite, my WIFI driver is having an error, so what I did, I uninstalled all things related to Killer Wifi App via CCleaner and then suddenly, the WiFi Icon appeared and it also started working as well. I hope this will work on your end.
i have the same problem like you. Have you done fixed it Loyd
If it helps anyone else with this problem, I went to Device Manager, selected Network Adapter and then double clicked on the Killer Wifi listing. I then selected Advanced tab and a list of wifi property options shows. I experimented with different ones until I found one that would allow me connect again. From there I searched and found the Intel support page for the Killer module and downloaded a relatively new software package of software and drivers and installed them. All has worked well since. https://www.intel.com/content/www/us/en/support/products/211604/wireless/intel-killer-wi-fi-products/intel-killer-wi-fi-series.html
