Wireless
8515 ディスカッション
Intel(R) Wi-Fi 6 AX200 160 MHz disconnects randomly (Code 10)
Robin07
ビギナー
1,855件の閲覧回数
Hi there.
I got a very weird issue with the PCIe Network Card I bought recently.
When I start my PC the network adapter works perfectly fine.
But sometimes it randomly disconnects, meaning that I cant find any network devices to connect to anymore.
In the device manager I then see a yellow exclamation mark next to the "Intel(R) Wi-Fi 6 AX200 160 MHz" and it gives a "Code 10" error.
When I refresh the devices in the device manager the device becomes hidden and the error-code changes to "code 45".
After restarting my PC, often the network adapter starts working again.
The error doesn't occure after a specific time. Sometimes the card works fine over the entire day and sometimes it disconnects inbetween my work.
Also I didn't notice starting any of my programs leds to this error.
Just sometimes when I start the PC from standby mode it already is disconnected.
I tried installing the driver provided with the Network Card, but also the latest drivers from the intel Website. But I always run into the same issue.
The manufacturer of the network card also sent me a replacement one, in case it was broken. But the issue persists.
I really don't know what to do anymore.
Maybe someone here has a tip, how I can get it running without the issue.
I ran the Intel System Support Utility Software when the error occured last time and attached the file here.
Thank you very much for your help!
0 件の賞賛
3 返答(返信)
David_G_Intel
モデレーター
1,829件の閲覧回数
Hello Robin07
Thank you for posting on the Intel️® communities. Please share more information with us:
  • Do you also get Bluetooth issues?
  • When did it start to happen?
  • Do you remember if this issue happened after a new OS update or Wireless driver update?
  • Is this a new computer?
  • Is this the original adapter that came pre-installed in your system or have you changed/installed a new adapter recently?
  • Were you able to have you wireless connection in a normal/expected performance before?
  • Have you installed any recent software or hardware in your system?
  • Have tried a roll back to a previous driver version for testing?
David G
David_G_Intel
モデレーター
1,798件の閲覧回数
David G.
David_G_Intel
モデレーター
1,772件の閲覧回数
David G.
返信
