So I have a P53 and my event viewer is having a ***** load of fun as it spawns everytime this error like 10 times per seconds.
I tried udpating the drivers to the latest 22.80.1 and it didn't change a thing.
Here is the SSU output : https://pastebin.com/5W9HW1a5
Thanks for your time !
I also get this warning, I would love to know the fix for this.
Hello LoukaOCh
Thank you for posting on the Intel️® communities. Please share with us the following information:
- Do you also get Bluetooth issues?
- When did it start to happen?
- Do you remember if this issue happened after a new OS update or Wireless driver update?
- Is this a new computer? If so, have check with your system's OEM for validated drivers or support on known issues related to the symptoms experienced?
- Is this the original adapter that came pre-installed in your system or have you changed/installed a new adapter recently?
- What steps do you take to reproduce your issue?
- Were you able to have you wireless connection in a normal/expected performance before?
- Have you installed any recent software or hardware in your system?
- Have tried a roll back to a previous driver version for testing?
- Did you try the drivers from the manufacturer already?
David G
David G.
David G.
