Wireless
8782 Discussions
Intel(R) Wi-Fi 6 AX200 can not start in 5GHz
Hidzaro
Не могу создать мобильный хот-спот с частотой работы 5ГГц. Подскажите пожалуйста в чём причина данной проблемы?
(Скриншоты приложил)
I can't create a mobile hot-spot with a frequency of 5GHz. Please tell me what is the reason for this problem?
(Screenshots attached)
DeividA_Intel
Hello Hidzaro,
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
· Download the Intel® SSU and save the application on your computer: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
· Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
· To save your scan, click Next and click Save.
2. Are you able to connect to a 2.4GHZ network via hotspot?
3. Are you able to connect to a 5GHz network (router)?
4. Have you updated Windows, including optional updates?
5. Do you have Wi-Fi issues when you try to connect to a regular network (router)?
Deivid A.
Hidzaro
Добрый день! Спасибо за ответ.
1. Приложил скан
2. Я могу создать точку доступа hotspot с частотой 2.4 ГГц и подключить к ней свои устройства.
3. У меня нет роутера так что я не могу это проверить.
4. Установлена последняя версия виндовс.
5. У меня нет роутера. Есть только Intel(R) Wi-Fi 6 AX200.
Good afternoon! Thanks for the reply.
1. Attached the scan
2. I can create a 2.4 GHz hotspot and connect my devices to it.
3. I don't have a router so I can't check it.
4. The latest version of Windows is installed.
5.I don't have a router. There is only Intel (R) Wi-Fi 6 AX200.
DeividA_Intel
Hello Hidzaro,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
DeividA_Intel
Hello Hidzaro,
In order to help you further with this issue I would like you to try the following:
1. BIOS update (you may need to check with MSI for the steps):
- https://www.msi.com/Motherboard/support/MAG-X570-TOMAHAWK-WIFI#down-bios
2. Use MSI wireless drivers, you can also use the previous link.
3. Performed a clean installation of Intel drivers (if MSI drivers did not work):
- Diver: https://downloadcenter.intel.com/download/30279?v=t
- Steps: https://www.intel.com/content/www/us/en/support/articles/000022173/wireless/intel-wireless-gigabit-products.html
4. Have you tried the following steps:
- https://support.microsoft.com/en-us/windows/use-your-pc-as-a-mobile-hotspot-c89b0fad-72d5-41e8-f7ea-406ad9036b85
5. If none of the previous steps worked, get in contact with MSI for further details.
Deivid A.
Hidzaro
Hello!
1. Я обновил биос с версии 1.4 до 1.5 но это не помогло.
2. У меня были установлены последние версии драйверов с помощью программы msi dragon center/
3. Я удали wi-fi драйвер и выполнил чистую установку, но это тоже не помогло.
4. Я могу включить hotspot для раздачи wi-fi только на частоте 2.4ГГц. Но не могу включить hotspon на частоте 5ГГц (сообщает ошибку: выбранный диапазон частоты недоступен)
1. I updated the bios from version 1.4 to 1.5 but it didn't help.
2. I had the latest drivers installed using the msi dragon center program.
3. I removed the wi-fi driver and did a clean install, but that didn't help either.
4. I can only enable hotspot wi-fi at 2.4 GHz. But I can not enable hotspon at a frequency of 5GHz (reports an error: the selected frequency range is not available)
DeividA_Intel
Hello Hidzaro,
Were you able to check the previous post? Please let me know if you need more assistance.
Deivid A.
DeividA_Intel
Hello Hidzaro,
Thank you for the information provided
Deivid A.
DeividA_Intel
Hello Hidzaro,
Based on the research I would like to let you know that this is expected behavior due to country-specific regulatory limitations, some countries that do not allow Hotspot to operate in 5GHz independently.
Something you can try would be the following:
Enabling method:
For current Wi-Fi 6 adapters (AX200 and AX201) you will have to:
- Update the Wireless driver including the related Firmware changes. (https://downloadcenter.intel.com/download/30279?v=t)
- Update the BIOS provided by the system manufacturer.
- Enable Wi-Fi 6 in BIOS (check the exact feature name with your system manufacturer).
If this does not work, could be due to the country limitation previously mentioned.
Deivid A.
DeividA_Intel
Hello Hidzaro,
Deivid A.
DeividA_Intel
Hello Hidzaro,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Deivid A.
