Hi
I have an almost new computer (desktop), se attached SSU report.
The AX211 reaches at maximum 100Mbit/s, normaly 80, while 2 different laptops and my mobile standing in the same spot reaches close to 500Mbit/s. All running towards the 5Ghz SSID
I just installed the latest driver (Intel Driver and support assistant) and ran a system scan and drive check with no remarks.
I bought the computer about 2 months with everything installed.
I actually can't say if this if it's a new problem but most probably not as nothing is changed, except windows updates, graphic card updates and today the driver version for this card.
Using Mobile hotspot do not help. neither moving the computer away some meters.
The router tells these are the available modes: 802.11 a and n and ac.
Windows 11
Br
Mats Sederholm
What Gen Wifi router are you using ? AC or AX or AXE , Wifi 5, Wifi 6, Wifi 6E. Intel AX 211 is a Wifi 6E ( with 6 Ghz band) card and may not play nice with Wifi 5 routers. Wifi 5 AC routers dont support the enhanced features of Wifi 6 and Wifi 6E network cards.
Cheers
3Fees
Hi 3Fees
Thanks for the input.
One of the laptops that works actually has a 6E card and ax. So the router 5ghz seem to make friend with this kind of card.
Hi:
Interesting yet not up to speed. Intel ax cards connect to wifi 6 routers at 160Mhz, AC wifi routers max at 80Mhz, your putting regular gasoline in a motor that requires premium plus wifi 6 has many other advantages over wifi 5- ac. Windows or M$ 10 is suited to wifi 5 Windows 11 wifi 6 support.
I'm running Intel 201AX card and was using a good quality AC router and my connection speed was not good, got a wifi 6 router now connected at 1.2GBs and can connect to 2.4Gbs by upping the connection speed in the wifi 6 gui. Do yourself a flavor and get a wifi 6 or 6E router to unleash your network your connection speed problems will be over.
Your all Welcome
Cheers
3Fees
Still no response from Intel!
The router can handle 6E adapters as already mentioned.
Since last time I bought myself a USB adapter and doubled the speed.
I also tried to adjust the atennas and that helped out a bit.
My plan is to make a Ethernet connection to the router and skip these problems.
It just consumes to much energy.
Unless someone can come up with any troubleshooting
Mats
Also on the MSI forum I was given a reference to Intel drivers so we're back to square 1
Drivers installed but card is not fast enough
Hello mseder,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® Wi-Fi 6E AX211 (Gig+).
1. What is the brand and model name of your router/AP?
2. DId you try updating the BIOS version (7E06v16, 2023-05-22)?
3. Did you try with the drivers from MSI (22.180.0.4)?
4. Is the Bluetooth working properly?
5. Did you check with MSI to confirm if there is any malfunction with the card?
Deivid A.
Hi Deivid
SagenCom F@st 5370e
https://www.telia.se/dam/jcr:238dd37a-8afa-4bdc-9c96-8778acb46ed2/Produktblad_Fast5370e.pdf
2 DId you try updating the BIOS version (7E06v16, 2023-05-22)?
No, where do I find it?
No. But, shouldn't Intels own drivers for their own product which I just installed be the best one?
I donät know, how do I check that?
No, I assume Intel would be the best source to know the status of their own product?
Mats
Hello mseder,
Thanks for the confirmation. Bear in mind that our drives are generic and the drivers from MSI are customized to work perfectly with their unit since they can add/remove/block features based on their needs.
You can access the wireless drivers and BIOS in the following link. However, I recommend you check with MSI for the proper steps to install their updates.
- Drivers and BIOS: https://www.msi.com/Motherboard/PRO-Z790-P-WIFI-DDR4/support#bios
Also, try to get in contact with MSI so they can run the test needed on their board to confirm any issues with their system.
Deivid A.
Ok Deivid, I'll check things out with MSI
Thanks so far
Mats
Hello mseder,
Thanks for your response. I understand that will check this issue with the manufacturer so they can run the tests needed for their computer.
I will proceed to close this thread, however, you can open a new one in case you need further support or if you face any issues with our products.
Deivid A.
Well
From my perspective issue is not solved, I let you now if this has anything to do with MSI.
Mats
Regarding drivers for card MSI seem to refer to
Intel Network Drivers
2.1.3.3
Intel WIFI Driver
22.180.0.4
Is that the same as the drivers of yours or?
I've also started a thread on their forum asking "who has the drivers for the Intel AX211 on a MSI Desktop"
Mats
Also the moderator on the MSI forum answered my question regarding what drivers I should use
"Strait from Intel"
Mats
Did you find a solution for your issue? I have the exact same problem on my LG Gram.
François
Hi
No I didn't, well as I wrote earlier "My plan is to make a Ethernet connection to the router and skip these problems.
It just consumes to much energy". That is how I solved it and reached the expected riuter speed 400 MB.
I have run every update since March when I bought the computer except installing a new BIOS. But can't see how that suddenly can increse the speed with 100%
Mats
Hey,
I'm planning on doing the same thing and just plug the computer on Ethernet.
This is such as shame for a company like Intel not to be able to fix a really important issue like this one.
Also, it seems that the problem occur on various brands. Your computer is an MSI, but mine is an LG Gram and I saw many posts regarding Samsung PCs.
So yes, I don't see how a BIOS update would magically fix the issue. It's purely an Intel-related problem.
François
Yes - I left everything - channel selection, channel width, etc. to automatic except preferred band set to " 5 and 6 ghz". Also used 2.5 gb/sec ports from router to ap.
With latest drivers on WiFi, average 680 mbs on wireless adapter, versus 1 gb on hardwired computer port. Using AX connection on 5ghz wireless.
![](/skins/images/76FBCD0056552B7B74FE0D35ED948B09/responsive_peak/images/icon_anonymous_message.png)
