Wireless
8537 ディスカッション
Intel(R) wifi 6 ax201 160mz not identifying any connections, Code 10
jdub91
初心者
2,251件の閲覧回数
Can't identify any internet connections. Tried a number of solutions online, must be doing something wrong. My Intel support utility file is attached.
ラベル(2)
0 件の賞賛
4 返答(返信)
jdub91
初心者
2,248件の閲覧回数
Bluetooth is also not showing up in device manager.
n_scott_pearson
スーパーユーザー
2,228件の閲覧回数
I suggest that you do a clean install of the Wireless and Bluetooth drivers. Here is my process:
  1. If you haven't already, download - but do not install just yet - the desired Bluetooth and WiFi driver packages for your adapter. Here are the current links for downloading these drivers: Wireless: https://www.intel.com/content/www/us/en/download/19351 and Bluetooth: https://www.intel.com/content/www/us/en/download/18649
  2. Disable Internet access. Unplug Ethernet cable and/or disable wireless. Keep disabled until told to re-enable.
  3. From the Apps & Features applet, check for instances of Intel PROSet/Wireless Software and Intel Wireless Bluetooth. If none, skip to Step 6.
  4. Uninstall each instance of Intel PROSet/Wireless Software and/or Intel Wireless Bluetooth that is present. When prompted, choose to "Discard Settings".
  5. Manually reboot your computer, keeping Internet access disabled throughout.
  6. From the Device Manager applet, check the Network Adapters section for an entry for Intel Wi-Fi 6 AX201 and check the Bluetooth section for an entry for Intel Wireless Bluetooth that has an intel driver associated with it. If neither is the case, go to Step 10.
  7. Right click on the entry for Intel Wi-Fi 6 AX201 and uninstall it, choosing to (checkmark) Delete the driver software for this device.
  8. Right click on the entry for Intel Wireless Bluetooth and open its properties. If it has an Intel driver associated with it, then uninstall it, choosing to (checkmark) Delete the driver software for this device.
  9. Go to Step 5.
  10. (Optional but recommended) Clean out all temporary files using the Windows Clean Disk tool. Ensure you have enabled cleaning of System Files. I recommend that you then checkmark all categories offered, even if no files currently in this category (so it leaves it set up for next invocation).
  11. (Optional but recommended) Clear each of your browsers' cache.
  12. Install the Bluetooth driver package (my rule: always install Bluetooth first).
  13. Install the Wireless driver package.
  14. Manually shutdown and reboot your computer.
  15. Reenable Internet access. Restore Ethernet cable and/or reenable wireless.
  16. Test.
Hope this helps,
jdub91
初心者
2,216件の閲覧回数
No luck on my end. The adapter is still coming up with a code 10 (cannot start). Thanks anyway
n_scott_pearson
スーパーユーザー
2,189件の閲覧回数
The part may have simply failed. It happens - not often but it does happen. Contact your manufacturer regarding a replacement.
Sorry,
返信
