Our company is currently in the process of obtaining CE, FCC, IC, and KC certifications for the robot we've developed.
We need certification documentation for the Intel Wi-Fi 6E module AX210NGW integrated into the robot.
Could you provide the required test reports and certifications for this module?
We'd also like to inquire about the availability of the external PIFA antenna datasheet.
Thank you for your help.
Hello kevin310,
- Can you further explain why you need the certification? You mentioned that it is for the robots that you developed, but why do you need the certification? Can you tell us more about it?
Michael L.
Hello kevin310,
I will do further research on this matter and post the response on this thread once it is available.
Michael L.
Hello kevin310,
I will send an e-mail to the e-mail address associated with your community profile regarding the information you are looking for, please check it out.
Michael L.
Hello kevin310,
Michael L.
Dear Michael L.
Thank you for your cooperation.
I will proceed as instructed.
I will contact you again if any issues arise.
Thank you.
Hello kevin310,
Thank you for the confirmation.
Because of this, I need to close this inquiry.
Michael L.
