- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi!
Windows 11 Enterprise / Windows 10 Enterprise
Version 23H2 / 22H2
Wifi : Intel(R) Wi-Fi 6E AX211 160MHz
Driver Version :" Intel 23.80.1.3"
We have issues with all of our new laptops that have the latest Wi-Fi 6E AX211 network adapter.
When we are using our software that are communicating with a SQL server internally it takes forever to load.
Seems like there is an unexpected latency.
With a older driver (22.250.10.1) it takes around 5 seconds, with the latest driver the same procedure takes around 3-4 minutes.
We have tried to change all kinds of Advanced settings on the Network Adapter, and nothing seems to work.
We have also checked our AccessPoint settings and tried to tweak some things there without success..
We have tried the latest driver (23.80.1.3) and we had to go way back to the driver (22.250.10.1) for it to work like expected and without any delay or latency.
The same issue occurs on a newly formatted Windows PC aswell.
Seems like something happened after the 23.xx release of the network driver.
コピーされたリンク
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
HI,
we have same problem. Problem was first detected 28.6.2024. After some days testing , I had change version driver back on number 22.250.1.2.
Unfortinuly new version drivers ( tested the latest drivers 23.40.0.4 , 23.50.0.6 and 23.60.1.2) are very slow in comunication type sql server - client.
I hope, that Intel it doeas has repair!!!!
Every actualization uploud new driver and I am still repairing .....
Radek Ryšan
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
The thing i have Done now is just removing the newer driver and use the old 22.250..
But i hope that intel has a solution or a fix for it.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello
I already recognized the problem at the beginning of 2024. I thought that this would be fixed over time. I became aware of the problem when opening the Windows Event Viewer remotely suddenly took an extremely long time. Unfortunately, the problem still exists. I opened a ticket with Microsoft and was then forwarded to Intel. I opened the ticket with Intel on 10/17/2024. Unfortunately, I don't have a solution yet, but the problem is in progress.
We currently have devices with newer Intel(R) Wi-Fi 6E AX211 160MHz where a driver downgrade to version 22.250.1, for example, is no longer possible. Presumably because the chip has a newer revision.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Seems like i was not alone with having issues. Hopefully they can find a solution.
And i might aswell open up a ticket with intel regarding this issue.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
We have the same problem. Many clients in Azure SQL database and each windows update, we have to uninstall the driver. It's really a shame that Intel does not take this problem seriously.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello.
Yes, i have a ticket/case with the Intel support and they are aware of the issue.
Seems like the problem was bigger then they expected. Have not yet heard about a solution or workaround except the one i found with a really old driver.
But the thing is that our new HP laptops seems like they have a new revision that does not support 22.250.1 driver.
So we are stuck here with no workaround or beta driver.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi
We have exactly the same problem. Also newer HP notebooks where an installation of an older driver is unfortunately no longer possible. I have not received any feedback from Intel regarding my ticket for weeks. I have already sent various logs.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi
We have the same problem too. It occurs on several hardware distributers and computer models, but they all use the AX210 or AX211. The installation of an older driver solves the problem, but I am concerned to roll out an old driver on several machines.
I also opened a support ticket and hope for the best.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Try driver version 22.250.0.4, A35. Works for us (Dell Latitude 5540 with Intel AX211). We've been having horrendous performance issues accessing SQL databases over Wi-Fi on v23.x drivers.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Tried installing the 22.250.0.4 aswell, but it cannot be installed on our newer HP laptops with the new AX211 revision.
It just says "Windows could not find drivers for your device".
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
We've been having the same exact issues. All the new Microsoft Surface Go 4s and Surface Pro 10s for business that we've purchased have this extra 500ms per sql query. We've seen this on AX211 and AX201 adapters. When we use an alternate wifi adapters, swap to a wired connection, or downgrade the driver to 22.220.0.4 the problem goes away. We've been buying alternate wifi adapters as a temporary measure until it gets resolved unfortunately.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Good news!
I have received a new preview test version from Intel (23.110.0.1) and according to my tests the problem is fixed!
I am currently in contact with Intel as to when the version will definitely be published.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
That sounds promising!
All i've heard so far is that they are trying to resolve it and the only thing i got as suggestion so far has been to downgrade.
But it's hard with the newer revisions when you can't downgrade the driver version.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Sounds great. Who at Intel should I contact to get the file?
We are in a really serious problem, a lot of computers are having this problem.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
We are currently having the same issues with one of our customers. Could you please share this version? Or, could you tell me where to obtain it?
Thanks in advance!
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
23.120.0 is available on Intel's driver dowload since 3/4/2025
I can confirm, the issue is solved.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Intel shared with me a setting change that fixed the issue for me. Hopefully it wont be necessary once they update the drivers, but maybe this will help others until then.
Enable FIPS Compliance
1. Wireless Network Properties
2. Security tab: Advanced Settings
3. Check Use FIPS compliant for this network.
4. After setting FIPS, select "Device Manager – Network Adapter – WIFI Network Card"
5. set "Disable Device" > "Enable Device" (required) OR - Reboot PC after setting FIPS (required)
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
I am facing this issue also with newer AX211 drivers, but not the old 22.250.0.
Is this issue resolved?
Anyone having good results with @Cyrrhus 's solution?
Thanks in advance!
