Wireless
8506 Discussões
Intel-Wireless-Driver-AX201-and-Wifi-Direct
Max1995
Principiante
1.081 Visualizações
Hello, I open new case linked to this one. community.intel.com/t5/Wireless/Intel-Wireless-Driver-AX201-and-Wifi-Direct/m-p/1711440#M61186, for reply to Mike, yes we have same problem with all drivers version.
10 Respostas
Mike_Intel
Moderador
770 Visualizações
Hello Max1995,
  1. Can you further explain the issue that you encounter? Please provide a detailed explanation.
  2. Did you manually install this AX201 in the system as an upgrade or this is embedded in the system?
  3. What is the brand and model of the system?
  4. Please help generate the SSU logs of your system for me to review the hardware and the installed drivers. Kindly refer to the link below on how to generate the logs:
Michael L.
Max1995
Principiante
755 Visualizações
Hello Mike, I've already did this thing its this topic community.intel.com/t5/Wireless/Intel-Wireless-Driver-AX201-and-Wifi-Direct/m-p/1711440#M61186 that you have closed
Mike_Intel
Moderador
716 Visualizações
Hello Max1995,
Thank you for pointing that out.
By the way, this was my last post in that thread before it was closed because I did not get a reply:
Based on SSU, you are already using the latest driver for the wireless controller which is 23.150.0
Let me clarify, may I know where did you get the driver 22.200.0.6 and this is for which device?
Lastly, let me also ask. Are you having issues with driver 23.150.0 for your wireless controller AX201?
Michael L.
Max1995
Principiante
629 Visualizações
Hello Mike, we download driver over the time directly from HP site for our device HP 840 G7, we also tried the same thing downloading the driver from intel site but nothing changes.
Also yes, the problem persists with the latest driver.
thanks
Mike_Intel
Moderador
498 Visualizações
Hello Max1995,
Thank you for the clarification.
Let's try to install the latest generic driver using clean driver installation method. Once done, please update me and if you are still having the same issue. Kindly generate a new set of SSU with updated drivers for further investigation. You may also share screenshots of the issue for me to check it in our lab.
Clean Installation of Wireless Drivers
Intel® Wireless Wi-Fi Drivers for Windows® 10 and Windows 11*
Michael L.
Max1995
Principiante
415 Visualizações
Hello Mike, we also tried in another pc (we have this problem in multiple pcs) with the clean installation but nothing change, here the thing, we start from this situation (miracast1.png) then we found that we have this:
47AC.7718::07/18/25-14:18:28.6940813 [server] - --> WimInit
47AC.7718::07/18/25-14:18:28.7005186 [server] - Init: enable soft AP or not: 1
47AC.7718::07/18/25-14:18:28.7005190 [server] - Init: enable WFD or not: 0
47AC.7718::07/18/25-14:18:28.7005218 [vlib] - --> VLibSetVirtualization
47AC.7718::07/18/25-14:18:28.7005222 [vlib] - Asked to program virtualization se
  • On a test device. Please remove the AllowWFD registry key at the Registry path
    HKLM\SOFTWARE\Microsoft\WlanSvc\
  • Since we have many devices affected, it is recommended to implement a script or Group Policy to automate the removal of the key.
  • Setting the key to 0 disables Wireless Display (WFD).
  • If the key is present with a value of 1 or 10000000, WFD is considered enabled.
  • The preferred configuration is for the key to be not present. Therefore, deletion is the recommended approach.
  • The presence of this key on the affected systems suggests that it was manually set in the past, as it is not created by default.
This is why im thinking that this driver on the frist installation, also create this key.
thanks
Mike_Intel
Moderador
362 Visualizações
Hello Max1995,
Thank you for the update.
I may have this issue check by our Engineer so please help provide a detailed information below:
  1. How many units are affected?
  2. Are the affected units having the same brand and model? Meaning the SSU that you provided before are the same for the affected units?
  3. Just to clarify, no issue with Wi-Fi connection? The issue is when using Miracast?
  4. If you can also provide a video of the issue, that would help in my simulation.
Michael L.
Max1995
Principiante
219 Visualizações
Hello Mike, so in order:
1. We have different brand vendor with this problem, for example hp 840 G7 or Lenovo T14, but both have same wifi driver
2. Yep, no issue with wifi, just miracast
3. I dont have a video but in this image, you can see the problem, when we press windows key+k, told us that device cannot support miracast connection, but if we remove this key or we change it in 1, works
thanks
Mike_Intel
Moderador
98 Visualizações
Hello Max1995,
Based on the error message, it seems that your system does not support Miracast. Because of this, I tried to check your hardware based on the SSU that you sent and here is what I found out. Kindly refer to the links below for the supported OS and Intel announcement regarding Wireless Display:
Frequently Asked Questions about Intel® Graphics Drivers Support for...
Product Discontinuation Notice for Intel® WiDi and Intel® Pro WiDi
I also recommend that you to check with Microsoft for further support.
Michael L.
Max1995
Principiante
37 Visualizações
Hello Mike, this is not right. System support miracast, so the hardware it's okay.
The thing is, that this regedit key, with 0 value, block Miracast to works and this key seems comes with an old version of this driver or the program intel pro, can you check this?
thanks
Responder
