Wireless
8695 Discussions
Intel latest Wireless drivers (20.100.0.4) are broken
KGian1
Your latest drivers (20.100.0.4) have issue with driver support features so you can't activate mobile hotspot under W10 or other features so i had to roll back to 20.90.0.7. See the cmd details below for both drivers:
Microsoft Windows [Version 10.0.17134.472]
(c) 2018 Microsoft Corporation. All rights reserved.
C:\WINDOWS\system32>NETSH WLAN show drivers
Interface name: Wi-Fi
   Driver                   : Intel(R) Wireless-AC 9560 160MHz
   Vendor                   : Intel Corporation
   Provider                 : Intel
   Date                     : 01/11/2018
   Version                  : 20.100.0.4
   INF file                 : oem149.inf
   Type                     : Native Wi-Fi Driver
   Radio types supported    : 802.11b 802.11g 802.11n 802.11a 802.11ac Unknown
   FIPS 140-2 mode supported : Yes
   802.11w Management Frame Protection supported : Yes
   Hosted network supported : No
   Authentication and cipher supported in infrastructure mode:
                               Open           None
                               Open           WEP-40bit
                               Open           WEP-104bit
                               Open           WEP
                               WPA-Enterprise TKIP
                               WPA-Enterprise CCMP
                               WPA-Personal   TKIP
                               WPA-Personal   CCMP
                               WPA2-Enterprise TKIP
                               WPA2-Enterprise CCMP
                               WPA2-Personal  TKIP
                               WPA2-Personal  CCMP
                               Open           Vendor defined
                               Vendor defined Vendor defined
   IHV service present      : Yes
   IHV adapter OUI          : [00 80 86], type: [00]
   IHV extensibility DLL path: C:\WINDOWS\system32\IntelWifiIhv08.dll
   IHV UI extensibility ClSID: {1bf6cb2d-2ae0-4879-a7aa-a75834fbd0e3}
   IHV diagnostics CLSID    : {00000000-0000-0000-0000-000000000000}
   Wireless Display Supported: No (Graphics Driver: Yes, Wi-Fi Driver: No)
KGian1
And for the rollback drivers:
   Provider                 : Intel
   Date                     : 25/09/2018
   Version                  : 20.90.0.7
   INF file                 : oem182.inf
                               Open           None
                               Open           WEP-40bit
                               Open           WEP-104bit
                               Open           WEP
                               WPA-Enterprise TKIP
                               WPA-Enterprise CCMP
                               WPA-Personal   TKIP
                               WPA-Personal   CCMP
                               WPA2-Personal  TKIP
                               WPA2-Personal  CCMP
                               Open           Vendor defined
   Wireless Display Supported: Yes (Graphics Driver: Yes, Wi-Fi Driver: Yes)
Leonardo_C_Intel
Hello KGian1 Thank you for posting in the Intel Community. • What is the model of the system? (brand and model). • Is the Intel® Wireless-AC 9560 the one that came pre-installed on the system? • What are the driver versions that work properly on the system? • Are you having any error message on the system at the time of enabling the Windows® mobile hotspot? If you do please provide me with a picture of the error. • Have you completed a wireless driver clean installation? (See the steps below). • If the unit continues to have issues, Please attach to this thread the TXT file the Intel® System Support Utility will generate: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility • Steps to save the report: 1- Run the utility. 2- Click on “Scan” to get the scanned system. 3- Once the scan is complete click on “next”. 4- Use the “save” option, save the report to your desktop. 5- To attach a file, you must click the “Attach” option on the bottom left-hand corner of the response box. • Intel wireless clean installation: https://www.intel.com/content/www/us/en/support/articles/000022173/network-and-i-o/wireless-networking.html. Hope this helps. Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation
KGian1
HP Zbook 17 G5
Yes
20.90.0.7 and older work properly
Yes i do, will provide in my next reply
Yes but will do it again to give you a detail log because i am a proficient user and while i know the new drivers are broken i know you won't fix it unless i give you this info
KGian1
Here is log for the working drivers:
KGian1
Here is log for the bad drivers. Also worth noting that after i did a clean install (with deleting the previous configuration) of the new drivers the problems are worst. There is difficulty connecting to the network, adapter seems to reset every 5s. Will try to update over the old working drivers to see if i can get them to work like before to show you the other error. Rolling back to the old drivers everything is working perfectly. Your new drivers are completely broken.
Leonardo_C_Intel
Hello KGian1 Thank you for the information, allow us to investigate the issue, we will be posting back as soon as news becomes available. Hope this helps. Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation
Leonardo_C_Intel
Hello KGian1 Thank you for waiting. I have tested the Intel® PROSet/Wireless Software and Drivers for Windows® 10 Version: 20.100.0 on an Intel® NUC Kit NUC8i7HVK in order to review the Microsoft mobile hotspot behavior and I did not faced any restriction or problem to enable the feature. • Is the system on an enterprise environment? • Are you having any red flag restriction reported on the Operating System? if you do please provide us with an screenshot of the windows settings, mobile hotspot options/error. • Have you tested the Intel® PROSet/Wireless Software and Drivers for Windows® 10 Version: 20.110.0 on the system? o Reference link: https://downloadcenter.intel.com/download/28503/Intel-PROSet-Wireless-Software-and-Drivers-for-Windows-10?product=99446. Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation
KGian1
Hello Leonardo.
I can confirm the hotspot issue at least has been resolved successfully with the latest 20.100.3 updates that came out 3 days ago. Thanks for notifying me to their release. I cannot confirm that everything else works smoothly though since i've just installed them, but assume if i don't reply back the drivers are working normally.
Leonardo_C_Intel
Hello KGian1 Thank you for letting me know that the system is working with the update. Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation
