Your latest drivers (20.100.0.4) have issue with driver support features so you can't activate mobile hotspot under W10 or other features so i had to roll back to 20.90.0.7. See the cmd details below for both drivers:
Microsoft Windows [Version 10.0.17134.472]
(c) 2018 Microsoft Corporation. All rights reserved.
C:\WINDOWS\system32>NETSH WLAN show drivers
Interface name: Wi-Fi
Driver : Intel(R) Wireless-AC 9560 160MHz
Vendor : Intel Corporation
Provider : Intel
Date : 01/11/2018
Version : 20.100.0.4
INF file : oem149.inf
Type : Native Wi-Fi Driver
Radio types supported : 802.11b 802.11g 802.11n 802.11a 802.11ac Unknown
FIPS 140-2 mode supported : Yes
802.11w Management Frame Protection supported : Yes
Hosted network supported : No
Authentication and cipher supported in infrastructure mode:
Open None
Open WEP-40bit
Open WEP-104bit
Open WEP
WPA-Enterprise TKIP
WPA-Enterprise CCMP
WPA-Personal TKIP
WPA-Personal CCMP
WPA2-Enterprise TKIP
WPA2-Enterprise CCMP
WPA2-Personal TKIP
WPA2-Personal CCMP
Open Vendor defined
Vendor defined Vendor defined
IHV service present : Yes
IHV adapter OUI : [00 80 86], type: [00]
IHV extensibility DLL path: C:\WINDOWS\system32\IntelWifiIhv08.dll
IHV UI extensibility ClSID: {1bf6cb2d-2ae0-4879-a7aa-a75834fbd0e3}
IHV diagnostics CLSID : {00000000-0000-0000-0000-000000000000}
Wireless Display Supported: No (Graphics Driver: Yes, Wi-Fi Driver: No)
And for the rollback drivers:
Provider : Intel
Date : 25/09/2018
Version : 20.90.0.7
INF file : oem182.inf
Open None
Open WEP-40bit
Open WEP-104bit
Open WEP
WPA-Enterprise TKIP
WPA-Enterprise CCMP
WPA-Personal TKIP
WPA-Personal CCMP
WPA2-Personal TKIP
WPA2-Personal CCMP
Open Vendor defined
Wireless Display Supported: Yes (Graphics Driver: Yes, Wi-Fi Driver: Yes)
• What is the model of the system? (brand and model).
HP Zbook 17 G5
• Is the Intel® Wireless-AC 9560 the one that came pre-installed on the system?
Yes
• What are the driver versions that work properly on the system?
20.90.0.7 and older work properly
• Are you having any error message on the system at the time of enabling the Windows® mobile hotspot? If you do please provide me with a picture of the error.
Yes i do, will provide in my next reply
• Have you completed a wireless driver clean installation? (See the steps below).
Yes but will do it again to give you a detail log because i am a proficient user and while i know the new drivers are broken i know you won't fix it unless i give you this info
Here is log for the working drivers:
Here is log for the bad drivers. Also worth noting that after i did a clean install (with deleting the previous configuration) of the new drivers the problems are worst. There is difficulty connecting to the network, adapter seems to reset every 5s. Will try to update over the old working drivers to see if i can get them to work like before to show you the other error. Rolling back to the old drivers everything is working perfectly. Your new drivers are completely broken.
Hello Leonardo.
I can confirm the hotspot issue at least has been resolved successfully with the latest 20.100.3 updates that came out 3 days ago. Thanks for notifying me to their release. I cannot confirm that everything else works smoothly though since i've just installed them, but assume if i don't reply back the drivers are working normally.
![](/skins/images/BC9A7A3465121B56B278007F4EE8899F/responsive_peak/images/icon_anonymous_message.png)
