- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Hello! Can some help me. I have notebook with Windows Server 2022 and i can't find driver for wi-fi module.
pci\ven_8086&dev_51f0&cc_0280
Thx for help
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello @Wisher
We understand you are looking for the driver for your Intel® Wi-Fi 6 AX201 (Gig+), we will be more than happy to assist you.
Please answer the following:
· Was it working before?
· Is that the original adapter that came pre-installed in your system?
Please keep in mind that the driver should be provided by the system manufacturer, in however, you can follow the instructions in this article Clean Installation of Wireless Drivers.
Also, in order to have more information about your system, please download, install and run Intel® System Support Utility for Windows. Make sure you check “Everything” before you scan, then save the report and attach it to your response.
Jose B.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello Wisher
We hope you are doing fine.
Were you able to perform the clean installation?
Let us know if you still need assistance by attaching the required report.
Jose B.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello Wisher
We hope you are having a nice day.
We have not heard back from you. So, we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jose B.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello Wisher
If your Intel® Wi-Fi 6 AX201 (Gig+) came pre-installed in your system and Windows Server was the operating system by default, please contact the OEM in order to check if they have a compatible driver supporting it since according to Supported Windows Operating Systems for Intel® Wireless Products operating systems such as Windows Server*, Mac OSX* and so on, are not supported.
Jose B.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
This seems to be an ongoing issue.
Installing the latest (and all other) Windows 11 drivers for the AX210 gives the error "A service installation section in this INF is invalid."
Rewriting the INF won't match the hash of the driver cat file so can you please rewrite one for Server 2022 that works but doesn't provide support? This will help thousands online looking for this same solution
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I had been working on this issue for a while. As soon as I posted a reply, I figured out the solution....
Uninstall Device in Device Manager
In PowerShell, run command "
Add-WindowsFeature -Name Wireless-Networking
Restart
If the drivers weren't installed already, download them, install them.
Restart
Should be good to go.
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
