Hello, i have on my laptop the Intel(R) Wi-Fi 6 AX201 160MHz.
Is it supports WiFi 6e? or just WiFi 6?
Thank you.
No WiFi 6E:
https://cdrdv2.intel.com/v1/dl/getcontent/607008
The AX201 adaptor only supports WiFi 6.
Sorry,
Thank you both for your answers. May I ask another question? If i have Intel(R) Wi-Fi 6 AX201 160MHz, what is the maximum WiFi speed I can get in real life? I have 2.5Gbps fiber at home.
Best I have ever done is 1201/1201 Mb/s. This is with TP-Link AX1800 router.
Thank you sir for your answer. I guess I'll just connect it with a wire to the laptop, with type-c adapter that supports 2.5Gbps.
Thank you.
