Wireless
8243 Discussions
Killer Wi-fi 6E AX1675x and Killer Network Service Problems
Darkness
I have a Killer Wi-fi 6E AX1674x adapter, and running Windows 11 Pro. I had this same problem on Windows 10 Pro, and to be honest, it's getting kind of annoying. I purchased the Killer Wi-Fi adapter for Wi-Fi 6 and the ability to manage it through the Killer App. Problem is, the Killer Network Service continuously stops running. I can manually start the service, but it only runs for 30 to 60 seconds, then stops again. I've uninstalled everything, uninstalled my anti-virus program, reinstalled everything, but the same problem occurs. The wi-fi adapter seems to work fine, but I am a gamer, and I'd like to be able to manage my connection and tweak it.
Even if I get this up and running, like I did on Windows 10 Pro for a little while, as soon as an update comes out and the Intel updater works its magic, I'm back to square one all over again.
Is there some way to fix the Killer Network Service?
Jose_Intel
Hello @Darkness
Thank you for posting on the Intel️® communities.
We sincerely regret you are experiencing issues, we will be more than willing to assist you.
Please answer the following:
·      Did it work properly before?
·      Is this issue happening at home, office environment or both?
·      Have you checked if this issue happens on different networks?
Also, in order to have more information about your system, please download, install and run Intel® System Support Utility for Windows. Make sure you check “Everything” before you scan, then save the report and attach it to your response.
Jose B.
IsaacQ_Intel
Hello Darkness,
We hope you are doing fine.
Isaac Q.
IsaacQ_Intel
Hello Darkness,
Best regards.
Isaac Q.
