Wireless
8566 Discussions
Killer Wireless-n/a/ac 1535 Wireless Network Adapter
satpassion
A few days ago they installed the gigabit fiber and when I'm connected via wifi a few inches from the modem, the internet speed is maximum 300Mbps while with the ethernet cable I get to 900Mbps.
I don't understand this remarkable difference in speed that I have on my MSI's laptop (GS72 6QE STEALTH PRO 4K).
The latest network card's driver installed is n. 12.0.0.722 dated 8/22/2018.
The Killer Wireless-n/a/ac 1535 Wireless Network Adapter supports a maximum speed of 866Mbps but I can't get above 300Mbps.
I don't understand what the problem is.
n_scott_pearson
Hhmmm, sounds like you are only connecting to the 2.4GHz band. Are you sure you are using the right SSID?
satpassion
Yes, because I created two different SSIDs. One for 2.4GHz and the other for 5GHz.
n_scott_pearson
Second possibility is that you are only connecting using Wireless-N, which would also limit you to 300 Mb/s. Check what type of connection you are actually getting.
satpassion
n_scott_pearson
You've verified that it is a 5GHz Wireless-AC connection but it won't go above 300Mb/s? Hhmmm... (grasping at straws) Have you verified that your antennas are connected properly to the card? If so, try swapping the leads.
satpassion
Sorry, but I didn't understand what kind of verification I need to do.
n_scott_pearson
Open your laptop and ensure that the antenna wires are properly connected to the wireless card.
satpassion
Unfortunately, I don't have the expertise to do this.
n_scott_pearson
I can only suggest that you find a friend or neighbor that has this level of expertise. A repair shop may be able to help you, though a cost may be involved there.
Sorry
JosueO_Intel
Hello satpassion,
Due to this product being discontinued, Intel Customer Service no longer supports inquiries for it, I am glad to see that fellow community members have the knowledge and they jumped in and are helping you. You may also find the Discontinued Products website helpful to address your request.
https://www.intel.com/content/www/us/en/support/discontinued-products.html
You can verify this product's discontinuance status at the Intel Product Specifications website > Product Status > "Discontinued".
Our recommendation, in this case, is to contact the system manufacturer and request specialized support for your system. It is important for you to know that Intel no longer provides drivers for this wireless card, the OEM is the one that will provide the latest drivers for your system.
Josue O.
