Wireless
8528 Discussions
Latest Ubuntu server 22.04.2 without install Intel AX200 WIFI Driver
matthewchin
Intel AX200 WIFI Driver is work in Win11, I installed ubuntu server thru virtual box 7.0.8.
I tried check with below and disable fast-boot in asus TUF B550-plus boot:
https://jianjiesun.medium.com/ubuntu-20-04-intel-ax200-wifi-driver-install-2ac4c0dc4601
sudo lshw -C network
uname -r
5.15.0-71-generic
ls -l /etc/modprobe.d/
iwlwifi.conf
ls -l /lib/firmware/ grep | iwlwifi-cc-a0
I can find iwlwifi-cc-a0-46.ucode inside it
but none wifi w* interface in
cat /etc/netplan/00-installer-config.yaml
network:
ethernets:
enp0s3:
dhcp4: true
version: 2
May I know how to turn wifi drive install and up in ubuntu ?
now, it only have ethernet driver installed, but I need use wifi.
Alberto_R_Intel
matthewchin, Thank you for posting in the Intel® Communities Support.
We will be more than glad to assist you with this matter.
I will do further research on this topic to try to provide the most accurate response to your inquiry or to point you in the right direction for support. As soon as I get any updates, I will post all the details on this thread.
Albert R.
matthewchin
Thank for eply.
I finally know I need install the virtualbox  extension pack and setup bridged as wifi card, it is ok now.
https://askubuntu.com/questions/282018/wifi-card-on-ubuntu-in-virtualbox-no-wireless-extensions
Alberto_R_Intel
matthewchin, You are very welcome, I just received an update on this matter.
Perfect, excellent, it is great to know that you were able to confirm that to install the VirtualBox extension pack and setup bridged as wifi card is needed in order to properly install the driver.
From our side, we always advise to install the latest (and stable) version of the mainline kernel, 6.3, from kernel.org, which includes the latest wireless firmware for the Intel AX200, version 74:
https://kernel.org/
Additionally, just in case, we recommend to check with the motherboard manufacturer to ensure the AMD system is upgradable and fully compatible with the Intel® AX200 module on Ubuntu Server OS.
Albert R.
