Wireless
8662 Discussions
My Intel Wireless Bluetooth keeps disconnecting, reconnecting on a loop...
CMarg5
Hello, I've been struggling with this issue and keep having to disable my bluetooth in Device Manager. I'm using Windows 10 1909 and I've tried updating the "device", uninstalling and reinstalling; I've tried using the "services.msc" to see if the bluetooth is running and on automatic startup.
At a last resort, I even reset my windows software but that did not help. Please, I do not know what to do thank you.
AlHill
Download, run, and ATTACH (using the paperclip under the toolbar) the results of this utility:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Doc
CMarg5
Here are the results
AdrianM_Intel
Hello CMarg5,
I am following up your thread, do you still need assistance if so please provide the following information?
  • Was it working properly before?
  • Do you see any error code in device manager? --> open device manager--> Network adapters ---> Intel® Dual Band Wireless-AC 3168 right-click ''properties'' --> in general tab it can show if it works fine or error codes.
  • Is this the original wireless card that comes preinstalled by the system manufacturer?
  • Are you connecting headphones via Bluetooth?
  • Have you checked if the wireless antennas are properly connected?
  • Have you tried different bands 2.4Hz or 5.0Hz?
Adrian M.
CMarg5
The Dual Band Wireless device works properly it says. Bluetooth has worked many times before but all of a sudden, this happens.
Wireless bands are fine, wireless network is fine.
AdrianM_Intel
Hello CMarg5,
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Adrian M.
AdrianM_Intel
Hello CMarg5,
Are you still facing the same behavior?
  • is this the original card the comes pre-installed on your system?
  • just to confirm, by resetting windows* is that a restore point or fresh image installation?
  • does it happen with different Bluetooth devices? what is the device that is connected via Bluetooth?
  • Are the antennas properly connected?
Adrian M.
AdrianM_Intel
Hello CMarg5,
Were you able to check the previous post?
Adrian M.
AdrianM_Intel
Hello CMarg5,
Adrian M.
