連結已複製
Have you tried completely uninstalling the existing drivers and then installing the same/latest drivers? If not, it might be worth a try.
The process is as follows:
- If you haven't already, download the latest/same driver packages for the dock and WiGig capability and store on system drive (to not attempt install now).
- Disconnect from internet (so doesn't automatically update any drivers from there).
- Completely uninstall all driver packages related to the dock and WiGig capability.
- Reboot.
- Install the latest/same driver packages for the dock and WiGig capability. Say no to any reboot requests along the way.
- If any of the driver packages had requested a reboot, manually do a reboot now.
- Reconnect to internet.
- Test.
Hope this helps,
Thanks. I tried this, and then my X1 Yoga saw the WiGig dock but would not connect. It just spun and would never connect. I ran Lenovo updates and now my Yoga won't even see the WiGig dock. Back to Square One.
Yes, everything was working great with the dock for over 2 years. Suddenly I had no internet connection and realized that it was because my laptop was no longer connected to the dock (where my network cable was attached). I can't imaged the dock just suddenly "went bad", but I supposed that's possible? I have no other machines with the WiGig antenna to be able to test it, unfortunately.
