Wireless
8787 Discussions
Netgear Wifi router WGR614 and Wifi card Intel PRO/Wireless 2200BG : no internet connection
<!-- /* Font Definitions */ @font-face {font-family:"FuturaA Bk BT"; panose-1:2 11 5 2 2 2 4 2 3 3; mso-font-alt:"Times New Roman"; mso-font-charset:0; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:135 0 0 0 27 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; text-align:justify; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"FuturaA Bk BT"; mso-fareast-font-family:"Times New Roman"; mso-bidi-font-family:"Times New Roman"; color:navy; mso-ansi-language:FR; mso-fareast-language:FR;} a:link, span.MsoHyperlink {color:blue; text-decoration:underline; text-underline:single;} a:visited, span.MsoHyperlinkFollowed {color:# 606420; text-decoration:underline; text-underline:single;} p {mso-margin-top-alt:auto; margin-right:0cm; mso-margin-bottom-alt:auto; margin-left:0cm; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} span.highlight {mso-style-name:highlight;} @page Section1 {size:612.0pt 792.0pt; margin:70.85pt 70.85pt 70.85pt 70.85pt; mso-header-margin:36.0pt; mso-footer-margin:36.0pt; mso-paper-source:0;} div.Section1 {page:Section1;} -->
I have a Netgear Wifi router WGR614 V6 installed as a switch on my ADSL router which operate correctly with 2 PC's connected : one tower (on which a Wifi USB key Netgear WG111 V2 is installed) and a laptop (on which a Wifi card Intel link 5100 AGN is installed). With this configuration, I have no problem to connect those 2 PC's to the internet.
I have connected second laptop (on which a Wifi card Intel PRO/Wireless 2200BG is installed). The Wifi access works correctly (SSID ok, clé WPA ok,...), but unfortunately the internet access doesn't work. For information :
- the last Windows XP pilote for the Wifi card Intel PRO/Wireless 2200BG is installed
- the IP address exists and is correct
- the WGR614 and all PC's together use 802.11g protocol
- the ping on http://www.google.com/ www.google.com site runs not too correctly, some packets are lost, and sometimes this ping command doesn't work (and, as I said, the internet access through Wifi doesn't work)
- the Intel work around on PSP feature doesn't improve anything
- changing the 802.11 modes on the WGR614 router doesn't improve anything
For information, by using an other Wifi access point (which is not a WGR614) the Wifi card Intel PRO/Wireless 2200BG runs correctly, and I can access the internet without any specific configuration with those 3 PC's.
Using a protocol analysis tool, I can see that there are a lot of TCP retransmissions, maybe it could be a track for the root cause...Maybe the WGR614 needs a specific configuration for the Intel PRO/Wireless 2200BG card ?
Thanks for your support if you could give me an answer about this issue.
Best regards.
Ha! I saw this same post over in the netgear forums. I answered there as well.
I had the same problem earlier this week, but I used a solution I found on a dell forum.
http://en.community.dell.com/forums/p/6197915/6871541.aspx
