Wireless
8695 Discussions
Notoriously appearing BSoD on Windows 10 Education during the active Hyper-V function
KKula
Hello, since I use the Hyper-V on a laptop, BSoD is notorious for me. I was looking for information on various forums, but I have not met with the problem of BSoD at Hyper-V on W10E.
BSoD was often preceded by slight short jams on the laptop accompanied by hum. Now more often the laptop just hangs for 2 minutes after which BSoD appears. Misfits appeared to me, for example, yesterday, when I received a message on Messengerze (I use the Messenger on the sidebar in the Opera). However, this is not a rule.
I also noticed that with the WiFi turned off and the Hyper-V turned on, the problem did not appear so often (maybe it did not appear at all).
So far, I have tried updating drivers, rebooting and rebooting the system, the format of the main drive. None of this helped.
The specificity of the computer:
Laptop model: Legion Y520 80wk
BIOS: 4KCN23WW
System: Windows 10 Education 64-bitowy
Processor: Intel(R) Core(TM) i5-7300HQ
Graphic cards: Inter(R) HD Graphics 630 oraz NIVIDIA GeForce GTX 1050
2 hard drives: 1 SSD - Patriot Hellfire M2, 2 HHD - ST1000LM035-1RK172
Network card: Inter(R) Dual Band Wireless-AC 3165
Link to files and screenshots dmp and EVE: https://1drv.ms/f/s!Agl7MhOL1yx7aoE3s4xFhcdXno0
WhyeBee_T_Intel
Hi KKula, Thank you for posting in Intel Ethernet Communities. I have moved your post to the Wireless Networking Communities, they can better assist you with the concern. Thank you. Best Regards, Whybe T Intel Customer Support Technician Under Contract to Intel Corporation
Wanner_G_Intel
Hello KKula, If you are still experiencing the issue reported, we would like to know if the blue screens occur after enabling Hyper-V or while using a virtual machine. Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation
KKula
Updating the system with the help of the System Update from the Lenovo has fixed the problem.
Thank you for your interest ;)
