Wireless
8527 Discussões
UX32VD - Intel Update Driver doesn't upgrade Intel Centrino Advanced-N 6235
DVass1
Principiante
4.917 Visualizações
I have serious issues with Wifi on my Asus UX32VD laptop running Windows 10 pro (64bits).
Ma Wifi connexion isn't stable, which increase loading pages time and download files time. The Intel update utility confirms to me that an update is available but it consistently fails. The installation process starts, but the utility tells me that the installation failed without Windows displaying any error message ...
I first tried to delete the driver but doesn't seem to help... I tried a manual driver installation by downloading the .exe file but the result is the same, the old driver is still being used ... Any idea?
4 Respostas
ASouz7
Colaborador honorário II
3.615 Visualizações
Hello DVAS,
Intel recommends that you always contact your computer manufacturer for assistance before trying any other alternative: http://www.intel.com/support/oems.htm Computer Manufacturer Support
The drivers for the Intel® Centrino® Advanced-N 6235 are supported by Windows*10 own inbox drivers. The drivers found in our Download Center are Windows 8.1* compliant and its version is the 18.20.0 as you can confirm here https://downloadcenter.intel.com/download/25276/Intel-PROSet-Wireless-Software-for-Windows-8-1- Download Intel® PROSet/Wireless Software for Windows 8.1*. and the file name is: Wireless_18.20.0_e164.exe
Alternatively, you can check the solutions below:
http://www.intel.com/support/wireless/sb/CS-030709.htm?wapkw=wifi+recommended+settings Wireless Networking — What are the Recommended Settings for 802.11n Connectivity?
http://www.intel.com/support/wireless/wlan/sb/CS-025332.htm Intel® Wi-Fi Products — Resolving Wi-Fi Network Connection Issues
http://www.intel.com/support/wireless/wlan/sb/CS-035591.htm Intel® Wi-Fi Products — Current Top 10 Frequently Asked Questions
http://www.intel.com/support/wireless/sb/CS-029893.htm Wireless Networking — Frequently Asked Questions - Wi-Fi
http://www.intel.com/support/wireless/wlan/sb/CS-032513.htm?wapkw=intel+wifi+link+5300+and+intel+wifi+link+5100+products Intel® Wi-Fi Products — Setting Wireless Adapter Power Management
You can also do the fowllowing if the above info did not resolve the issue:
1 - Change the channel on the router for one less crowded. Check this link for addtional information: http://www.intel.com/support/wireless/sb/CS-025344.htm Wireless Networking — What Are the Supported Wi-Fi Channels for IEEE* 802.11n 40 MHz?
2 - Make sure the router firmware is updated as well.
3 - Download and save https://downloadcenter.intel.com/download/25276/Intel-PROSet-Wireless-Software-for-Windows-8-1- Download Intel® PROSet/Wireless Software for Windows 8.1*. File name: Wireless_18.20.0_e164.exe
4 - Go to Control Panel, Programs and Features and Uninstall "Intel® PROSet/Wireless Software", if it is installed. When prompted, choose the option to "Discard settings"
5 - In Control Panel, Device Manager, Network Adapters, right click on the Intel® Centrino® Advanced-N 6235 and uninstall it. Make sure you mark the option to "Delete the driver software for this device".
6 - Reboot the PC or scan for hardware changes, check device manager and if an older driver is detected and installed, repeat the actions to uninstall and delete it as well. Repeat this process until the OS does not allow deleting the driver, or until the controller shows as Unknown Device.
7 - Then, proceed with the installation.
DVass1
Principiante
3.615 Visualizações
Nothing worked... Even worse, I now have bluetooth driver issues...
ASouz7
3.615 Visualizações
DVAS,
What are the issues you are encountering with the Bluetooth*. Please provide all details possible.
DVass1
Principiante
3.615 Visualizações
Bluetooth Drivers were uninstalled, I had to reinstall it to get my bluetooth work.
Even after installing https://downloadcenter.intel.com/download/25276/Intel-PROSet-Wireless-Software-for-Windows-8-1- Download Intel® PROSet/Wireless Software for Windows 8.1*. File name: Wireless_18.20.0_e164.exe (took me 2 hours) the 15.18.0.1 driver is still used...
Any way to force install for the newest driver ?
Responder
