Wireless
8651 Discussions
Very slow upload speed with intel wifi 6 ax200
Milanche
Hello!
I'm using a pc (windows 10 home) with MSI B550 gaming carbon wifi motherboard with built in intel wi-fi 6 AX200. I'm on a wifi network with TP-Link AX6000 router. The problem is that I have very low (feels like artificially limited) UPLOAD speed. No problems with DOWNLOAD speed. (every device is with the latest firmware/drivers).
Sitting at the same place with my iphone 11 pro max i'm getting speeds as shown on the picture.
What could be wrong..?
Thanks!
SSID: MIKSU
Протокол: Wi-Fi 6 (802.11ax)
Тип безопасности: WPA2-Personal
Диапазон сети: 5 ГГц
Канал сети: 36
Скорость линии (прием и передача): 1201/1201 (Mbps)
Локальный IPv6-адрес канала: fe80::38fc:b6b:ad31:7ff%2
IPv4-адрес: 192.168.0.101
DNS-серверы IPv4: 192.168.0.1
Изготовитель: Intel Corporation
Описание: Intel(R) Wi-Fi 6 AX200 160MHz
Версия драйвера: 22.50.1.1
Физический адрес (MAC): AC-12-03-D6-3B-4D
Milanche
SOLVED!
In the MSI Center software (that comes with the motherboard) there is a feature called LAN manager. Turned it of and everything works perfectly!!!
Milanche
del
Milanche
SOLVED!
Sutrisno
I literally made an account just to say thanks. I literally spend 500-700 euros to upgrade my Wi-Fi as the performance was getting worse and I thought it initially was my router / setup.
But finally thanks to you I found out the problem as well. It was LAN manager from MSI Dragon centre... turned it off and voila.
Blazing fast WiFi speeds. REALLY happy.. Thank you so much!
Milanche
You’re welcome my dear friend
SeePayne
Wow! I've been trying to figure out why my upload speeds have been practically nonexistent for months now. I bought a MSI graphics card back in September. I'll be honest, this article kept popping up in my searches every time and I always dismissed it because I had forgotten I downloaded and installed Dragon Center after I installed the gpu. So,  I just went into the software, turned off the LAN mananger and boom! Upload speeds restored! So thank you for this helpful piece of info. I feel stupid now for dismissing this article now lol
Milanche
DeividA_Intel
Hello Milanche,
I am glad to know that you noticed the source of the issue, and tracked it to the configuration at the MSI tool.
Also, I recommend you to get in contact with the motherboard manufacturer to get more details of your computer and tools if needed.
Deivid A.
DmitryKrasnov
Привет.
Smart Connect - выключи
5ггц выставляешь канал 44 или выше
160мгц
на адаптере \
2,4 - а
5 - ax
предпочитать  5гц
и так я 2400 мб сек / ax200 / 3,4млс  пинг
Milanche
Спасибо. Но выше описал в чем была причина у меня.
