Wireless
8516 Discussions
What is the Tx Output Power for AC-9260 using BLE?
T22
The Intel AC-9260 is spec'd for a Tx Output Power  = 10dBm (+/- 2dB) for BR and BLE (Long Range @ 125K).
1) What is the Tx Output Power for BLE @ the 1Mbps?  Also what is the Rx sensitivity?
2) What Tx output setting does the AC-9260 firmware default to?
[Note: the firmware on it is using HCI cmds so firmware on it must set it one way or another, or default]?
3) How to change the Tx output power? I tried this and I can't change and it just always show a value of 12?  What does 12 mean? 12 dBm or some index?
> sudo hciconfig hci0 inqtpl
hci0: Type: Primary Bus: USB
BD Address: 3C:6A:A7:40:8D:8B ACL MTU: 1021:4 SCO MTU: 96:6
Inquiry transmit power level: 12
I do this to try to set it, e.g. 10. I do get an error and this command does not go thru.
> sudo hciconfig hci0 inqtpl 10
Thanks for your time.
JedG_Intel
Hello T22,
I understand that you'd like to know the Tx Output Power for AC-9260 using BLE. I do not have an answer at this moment but I’ll investigate it and contact you back as soon as possible.
Jed G.
JedG_Intel
Hi T22,
After checking internally, I see that you need to contact RDC to gather the information that you need. For instructions on how to apply for an RDC account, please refer to the following link: How to Apply for an Intel® Resource and Documentation Center
Should you have other questions or concerns, please let me know.
Jed G.
JedG_Intel
Hello T22,
I wanted to check if you had the chance to review the information I posted. Please let me know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Jed G.
JedG_Intel
Hello T22,
Jed G.
